Domain of a composite function
11 replies · 2K views · last reply
songoku
TL;DR
Let say I have f(x) = ##-x^2 + 3 , x \leq 0##. I want to find the domain of composite function ##ff^{-1}## and ##f^{-1} f##
##f(x)=-x^2 + 3## so ##f^{-1} (x)=- \sqrt{3-x} ~, x \leq 3##
##ff^{-1} = - (- \sqrt{3-x})^2 + 3 = x## and the domain will be ##x \leq 3##
##f^{-1} f = - \sqrt{3-(-x^2+3)} = -x ## and the domain will be ##x \leq 0##
My question:
##ff^{-1} (x)## or ##f^{-1} f(x) ## is not always equal to ##x## and their domain can be different?
Thanks
songoku said:
Summary:: Let say I have f(x) = ##-x^2 + 3 , x \leq 0##. I want to find the domain of composite function ##ff^{-1}## and ##f^{-1} f##
My question:
Thanks
Here ##ff^{-1} (x)## and ##f^{-1} f(x) ## are equal (= x) on their common domain, which is ##x \le 0##. Outside that common domain, one or both of ##ff^{-1} (x)## and ##f^{-1} f(x) ## don't necessarily result in x.
For example, f(x) is defined at x = 1, but outside of the restricted domain of this problem.
##f^{-1}(f(1)) = f^{-1}(2) = -\sqrt{3 - 2} = -1 \ne 1##
I try using ##x=-6## which in their common domain.
##ff^{-1} (-6) = f(-3) = -6##
##f^{-1}f (-6) = f^{-1}(-33) = -6##
But from my working in post#1, ##f^{-1} f = - \sqrt{3-(-x^2+3)} = -x \rightarrow f^{-1} f(x) = -x##
So, ##f^{-1} f(-6) = - (-6) = 6## which is clearly wrong but I do not understand why. Is ##f^{-1} f(x) = -x## correct?
I thought the domain of ##f^{-1} f(x)## is ##x \le 0## so we can not put ##x=1## to ##f^{-1} f(x)## because it is outside the allowed domain?
Thanks
The above should be ##f^{-1}( f(x))##
No, the correct result is in the work near the top of this post; namely ##f^{-1}(f (-6)) = f^{-1}(-33) = -6##
No. Keep in mind that the domain of f is ##x \le 0##.
##f^{-1}( f(x)) = f^{-1}(-x^2 + 3) = -\sqrt{3 + x^2 - 3} = -\sqrt{x^2} = -|x|##
But since ##x \le 0##, then |x| = -x, so -|x| = x.
Hence ##f^{-1}( f(x)) = x, which is the right result for the composition of a function and its inverse.
I mentioned in my previous post that x = 1 was not in the restricted domain of f, but we could still do the calculation of ##f^{-1}( f(x))##.
[/quote]The above
You mean I should use bracket for "f(x)" part or maybe you have other purpose stating this part?
Hence ##f^{-1}( f(x)) = x##, which is the right result for the composition of a function and its inverse.
Actually I have note from teacher saying this exact thing: "the composition of a function and its inverse will always be equal to ##x##"
When I was practicing, I encounter problem on post#1 and I am confused why ##f(f^{-1}(x))## is ##x## but ##f^{-1}( f(x))## is ##-x##
You have explained that actually my working is wrong, both should be equal to ##x##
So the composition of a function and its inverse will always be equal to ##x##?
Oh, I thought we can only use value of ##x## in the restricted domain. Same as ##f(x)##, the domain is ##x \le 0## so I thought we can not put ##x > 0## into ##f(x)##
If I want to draw the graph of ##f(f^{-1}(x))##, should I just draw ##y=x## that extends from ##(-\infty , \infty)## or I draw ##y=x## that extends only from ##(-\infty , 3]## ?
Thanks
Yes, because ##f^{-1]f## could be mistaken for the product rather than the composition of the two functions.
Yes, but only on their shared domain.
For the functions of this problem, only the part of the line y = x that's in the third quadrant; i.e., for ##x \in (-\infty, 0]##.
Sorry I don't understand why it should be only the 3rd quadrant part
Is ##x \le 3## the correct domain for ##f(f^{-1}(x))## ?
For that composition, yes, but for ##f(f^{-1}(x))## to be equal to ##f^{-1}(f(x))##, we need the domain that both functions share: ##x \in (-\infty, 0]##. On that interval, the line y = x is in only the 3rd quadrant.
So if I only want to draw graph of ##f(f^{-1}(x))##, I still have to take the domain of ##f^{-1}(f(x))## into consideration? I can not just consider only domain of ##f(f^{-1}(x))## eventhough that is the graph I want to draw?
Thanks
No, that would be the line y = x, for ##x \in (-\infty, 3]##. For the graph of the other composition, ##y =(f^{-1}(f(x))##, that would be the same line, but for ##x \in (-\infty, 0]##.
What I said was for both compositions to be equal, we have to be using the common domain, ##x \in (-\infty, 0]##.
I suppose all the ##\infty## is typo, should be ##-\infty## instead.
Thank you very much for all the explanation Mark44
Yes, I neglected to add the minus sign. I've edited my post to correct them.
