Domain of multivariable function - definition
13 replies · 3K views
Poetria
(Choose all options below that correctly complete the following sentence.)
The domain of a multivariable function z=f(x,y) is:
-a subset of the real numbers
-a union of two subsets of the real numbers
-a subset of the xy-plane
-the union of the set of all values x where f(x,y) exists with the set of all values where f(x,y) exists
-the set of all ordered pairs of points (x,y) so that f(x,y) exists
I think that only the last definition is complete: "the set of all ordered pairs of points (x,y) so that f(x,y) exists"
E.g. all real numbers could be a domain but not necessarily, etc. Am I right?
Poetria said:
Homework Statement:: (Choose all options below that correctly complete the following sentence.)
Relevant Equations:: I think that only the last definition is complete: "the set of all ordered pairs of points (x,y) so that f(x,y) exists"
If the real numbers were the domain, given any real number (e.g 0), you should be able to compute its image. If you have a function ##f(x,y)## how do you compute the image of 0? Or the image of any other real number?
Let the function (x,y) be z=(x+y)/x. Well, I can try to compute it: z=(x+0)/0, but it will be undefined.
I guess the image of function is its range?
The image of a function for an element ##a## is the value of ##f(a)##. You are concentrating on the fact that 0 is undefined because is in the denominator, which makes you ignore the real problem. What is the image of your function for the real number 1 which has no problem with division?
Or if you define another function ##z=f(x,y)=x+y##, take any real number, what is its image?
I agree with your choice of last option but I think there is one more option that is also correct. Which do you think it is?
I thought that this one "the union of the set of all values x where f(x,y) exists with the set of all values where f(x,y) exists" may be correct, but I wasn't sure.
Is the union of two such sets an equivalent of ordered pairs?
Well, if z=f(x,y)=x+y, I can take x=1, but I would also need the value of y.
z=1+y
Is the union of two such sets an equivalent of ordered pairs?Well, if z=f(x,y)=x+y, I can take x=1, but I would also need the value of y.
z=1+y
Therefore the image of a real number makes no sense. So, can the real numbers (or a subset of real numbers like "the union of the set of all values x where f(x,y) exists with the set of all values where f(x,y) exists") be the domain of the function?
No this is not the option I had in mind and also to answer your very last question, the union of two such sets is not an equivalent of a set of ordered pairs.
For example take the function $$f(x,y)=\frac{1}{x-2}+\frac{1}{y-3}$$. The set of where is defined with respect to x let's call it ##A_x=\mathbb{R}-\{2\}##, while the set where is defined with respect to y is ##A_y=\mathbb{R}-\{3\}##. The union of ##A_x## and ##A_y## is the whole ##\mathbb{R}##, but the function is not defined in the whole ##\mathbb{R}## it is only defined for $$A=\{(x,y)\in \mathbb{R^2}:x\neq 2 , y\neq 3\}$$
Sorry i had some typos in my last post, I think now all typos fixed.
For example take the function $$f(x,y)=\frac{1}{x-2}\frac{1}{y-4}$$. The set of where is defined with respect to x let's call it ##A_x=\mathbb{R}-\{2\}##, while the set where is defined with respect to y is ##A_y=\mathbb{R}-\{3\}##. The union of ##A_x## and ##A_y## is the whole ##\mathbb{R}##, but the function is not defined in the whole ##\mathbb{R}## it is only defined for $$A=\{(x,y)\in \mathbb{R^2}:x\neq 2 , y\neq 3\}$$
Great explanation. :) Many thanks.
In that case I think the only option is this one "a subset of the xy-plane". My reservation was that there is no mention about if the function exists.
yes that's the option i had in mind. The way I read this option is "A subset of the xy plane where the function exists (or is well defined)"
Thank you so much. :) I got it. :)
Actually, there's no need to add any extra information, the phrase
"The domain of a multivariable function z=f(x,y) is a subset of the xy-plane"
is perfectly fine as it is.
As Keith Devlin said, it's about mathematical thinking. It's clear to you but it wasn't clear to me. I suppose the term 'subset' is the key. It implicates a subset where the function is well-defined.
