Calculating x for Perpendicular Vectors A and B: Dot and Cross Product Homework
The discussion revolves around determining the value of x for vectors A=(x,3,1) and B=(x,-x,2) such that the vector C=(10,-4,-4) is perpendicular to both A and B. Participants explored using the cross product A x B and the dot product A · C = 0 and B · C = 0. The calculations yielded conflicting values for x: 1.6 from A · C and 0.4 from B · C, indicating a potential issue with the problem statement itself. The consensus suggests that the problem may be misprinted, as no consistent value for x exists.
  • Understanding of vector operations, specifically cross product and dot product.
  • Familiarity with vector notation and properties of perpendicular vectors.
  • Basic algebra skills for solving equations involving variables.
  • Knowledge of linear algebra concepts related to vector spaces.
  • Review the properties of vector cross products and their geometric interpretations.
  • Study the conditions for vector perpendicularity using dot products.
  • Examine common pitfalls in vector calculations, particularly with variable components.
  • Investigate potential errors in problem statements and how to verify their accuracy.
Students in linear algebra, educators teaching vector mathematics, and anyone involved in solving vector-related problems in physics or engineering.
Outrageous
A=(x,3,1) ,B=(x,-x,2)
Determine the value of x if the vector perpendicular to A and B is given by C=(10,-4,-4)
Find A cross B , let A cross B be D . Then D cross C = zero (since they are perpendicular to both A and B) . This sounds logic but there will not be an answer for x. What is wrong?
Then I tried to use dot product A dot C=0, and B dot C=0. Yet the answer of two x are different.
Please guide. Thanks
You haven't shown your calculations. But perhaps there is no real value of x that works. Perhaps the problem is mis-printed or copied incorrectly.
So the both ways to solve the problem are correct?
I didn't say that. I haven't worked the problem; that's your job. If you want me to comment on what you did you need to show your work.
The first way
Sorry a, my camera not good.
Please look at the picture, I don't know why I can't upload more picture.
The second way, A dot C = 0 , x= 1.6
B dot C = 0 , x= 0.4
Thanks
I won't try to read upside down. But if your arithmetic is correct and you get different values for ##x##, that would tell you there is no solution. Like I said earlier, perhaps the problem is mis-printed or copied incorrectly.
Thanks
I would like to remark that your approach with the cross product is over-complicated. Once you found C = A x B, and assume that C is parallel with D, you can say C = k D, where k is some number. You do not need to cross-multiply C and D, you just need to confirm that C = k D is possible.
Really easier. But I think the question have some problems. Thank you.
