The Dot Product and Cross Product: Finding the Angle Between Two Vectors
The discussion centers on the relationship between the dot product and cross product of two vectors A and B, specifically in determining the angle theta that satisfies the equation A dot B = |A x B|. The correct angle is established as 315 degrees, corresponding to a smaller angle of 45 degrees, while 225 degrees is incorrect as it corresponds to an angle of 135 degrees. The magnitude of the cross product is clarified as |A x B| = |A||B| sin(theta), emphasizing the importance of using the smaller angle between the vectors in calculations.
  • Understanding of vector operations, specifically dot product and cross product.
  • Familiarity with trigonometric functions, particularly sine and cosine.
  • Knowledge of angles in standard position and their corresponding measures.
  • Basic principles of vector magnitude and direction.
  • Study the properties of vector operations in depth, focusing on dot and cross products.
  • Learn about the geometric interpretation of angles between vectors.
  • Explore trigonometric identities and their applications in vector mathematics.
  • Investigate the implications of using different angle measures in vector calculations.
Students of mathematics, physics enthusiasts, and anyone studying vector calculus or linear algebra who seeks to deepen their understanding of vector relationships and operations.
raptik
If theta is the angle between two non-zero vectors A and B, then which of the following angles theta results in A dot B = |A x B|?
A dot B = ABcos(theta)
A x B = ABsin(theta)
There were two choices in the multiple choice answers where cos(theta) = |sin(theta)|
1 is 225 degrees and the other is 315 degrees. The correct answer is 315 degrees. Can somebody explain or help illustrate why 225 is wrong and 315 is right?
When performing the dot and cross product the angle used in the formulas you listed is always the smaller angle between the two vectors. So an angle of 315 degrees corresponds to an angle of 45 degrees (360-315=45). And 225 corresponds to an angle of 135 degrees. This should help you answer your question.
Additionally the Magnitude of the cross product is defined as:
|A x B|= |A||B| sin(theta)
not = |AB sin(theta)| or AB |sin(theta)| as you eluded to in your post.
True as long as we agree that 0° ≤ θ ≤ 180°, as is common practice. But apparently the question's author has a different idea about the angle between two vectors!
