Dot Product of a Vector and its Derivative- Reality
The discussion centers on the relationship between a vector and its derivative, specifically addressing the dot product and its implications in physics. The participants clarify that the equation A dot B = AB is only valid under specific conditions, particularly when A is a constant length vector. They emphasize that in general scenarios, particularly in astrodynamics, the inner product of a vector and its derivative does not yield the norm product unless certain criteria are met. The confusion arises from the misinterpretation of the conditions under which these mathematical shortcuts apply.
  • Understanding of vector calculus and dot products
  • Familiarity with derivatives of vector functions
  • Knowledge of astrodynamics and orbital mechanics
  • Basic concepts of orthogonality in Euclidean space
  • Study the properties of vector-valued functions and their derivatives
  • Learn about the conditions for orthogonality in vector calculus
  • Explore the implications of the dot product in astrodynamics
  • Investigate the trajectory equations in the context of the two-body problem
Students and professionals in physics, particularly those focusing on vector calculus, astrodynamics, and orbital mechanics, will benefit from this discussion. It provides clarity on the mathematical relationships between vectors and their derivatives in practical applications.
mjxcrowley
Hey everyone,
This has been bugging me for a bit. I think I'm probably missing something pretty easy.
A dot B= ABcos(θ), where θ is the angle between A and B.
There is the little shortcut that says where B is the derivative of A, A dot B= AB. Clearly then cos(θ) = 1, and the angle between a vector and its derivative is 2nPi, where n=0, 1, 2... Intuitively this would not be true, and is clearly not true for an orbit (which is what I use it for). There the angle between R and V where V is the derivative of R is 90°+the flight path angle.
What am I missing? How are both these things true?
Note: I don't want to mathematical derivation of the shortcut. I have that. I want to understand it in reality.
I hope this is in the correct forum
Both of these things are false.
The inner product of a vector ##{\bf A}(t)## and it's derivative ##{\bf B}(t) = \frac{d {\bf A}(t)}{dt}## is equal to ##||{\bf A}|| \, ||{\bf B}||## only in the special case that ##{\bf A}(t) = A(t)\hat {\bf a}##, where ##A(t)## is a scalar and ##\hat {\bf a}## is a constant vector.
The inner product of a vector ##{\bf A}(t)## and it's derivative ##{\bf B}(t) = \frac{d {\bf A}(t)}{dt}## is zero only in the special case that ##{\bf A}(t)## is a constant length vector. Only circular orbits satisfy this condition; not all orbits are circular (in fact, almost all orbits are not circular).
My confusion I guess is that the relationship A dot B= AB where B is the derivative wrt time of A is often used generally in Astrodynamics texts. It doesn't seem generally correct, but it appears everywhere as a mathematical shortcut.
Where have you seen that? Are you sure you aren't confusing that with A cross B, which is equal in magnitude to AB in the case of a circular orbit?
I'm having a very hard time with the symbols. I'll try and explain then.
While deriving the trajectory equation for the general two body problem, it says:
r(vector) dot r(vector, dot) = r r(dot)
where the dot within the parenthesis represents the dot written above the variable to indicate derivative. The dot without the parenthesis is the dot product.
I apologize that that was so clunky but I tried to use the sigma button, and could not get it to work.
That's different. You mean ##\vec r \cdot \dot{\vec r} = r\dot r##.
Note very well: The ##\dot r## in that expression is not the magnitude of the velocity vector. It is instead the time derivative of the radial distance between the two orbiting bodies.
Here's the derivation. I'll work in cylindrical coordinates, where ##\hat r## is the unit vector along the radial vector, ##\hat z## is the unit vector along the angular velocity vector, and ##\hat{\theta}## completes the right hand coordinate system (with ##\hat r \times \hat {\theta} = \hat z##). With this, the radial vector is ##\vec r = r \hat r##. Taking the time derivative yields ##\dot{\vec r} = \dot r \hat r + r\dot{\hat r}##. The second term is necessarily orthogonal to radial vector. Thus ##\vec r \cdot \dot{\vec r} = r \dot r##.
From the calculus of vector valued functions a vector valued function and its derivative are orthogonal. In euclidean n-space this would mean cos Θ = 1 and hence the dot product of A and B would be the norm of A times the norm of B.
So my understanding of your question is you want to know why.
To see why this is true consider R(t) = f(t) i + g(t) j where i and j are standard basis vector and f and g are parametric equations describing a curve in the plane. The derivative would then be
R'(t) = lim Δt → 0 R(t + Δt) - R(t)/Δt
So now draw a vector from the origin to the point on the curve at t + Δt and then draw another vector a t. These two vector would be R(t + Δt) and R(t) respectively. Now draw a vector pointing from t to t + Δt on the curve at those values. This arrow would be the numerator in the limit above. Now decrease Δt and you will see that this vector will soon be tangent to the curve at t and it will be visually clear that it is orthogonal.
TheOldHag said:
From the calculus of vector valued functions a vector valued function and its derivative are orthogonal. In euclidean n-space this would mean cos Θ = 1 and hence the dot product of A and B would be the norm of A times the norm of B. …
That's just, on wrong both accounts. A vector valued function and its derivative are not necessarily orthogonal, and when they are, the inner product would be zero, not the norm of A times the norm of B.
You're right. I must have had brain leakage. I believe I'm a bit off on orthogonality too. I believe they are orthogonal only when the norm of R(t) is constant on an interval.
In general, I'm not seeing how the statement A dot B = norm(A) * norm(B) can be true since a vector valued function and it's derivative are not generally scalar multiple of one another.
Sorry for the confusion.
As I wrote in post #2, it's not true.
What is true is that ##\displaystyle{\vec A \cdot \frac{d\vec A}{dt} = ||\vec A||\,\frac{d\,||\vec A||}{dt}}##
Thank you so much DH. I was confused and you were extremely helpful.
  • · Replies 33 ·
