Can double convolutions be simplified using a change of variable?
  • Thread starter Thread starter muzialis
    Convolution
The discussion revolves around simplifying the expression for double convolutions, specifically the integral form of $$A \star \mathrm{d}x \star \mathrm{d}x$$. The user seeks a more compact representation of the double convolution integral, particularly regarding the limits of integration in the inner integral. There is a suggestion to utilize a change of variable, $$t - \tau = w$$, to achieve this simplification. Additionally, the conversation highlights the potential confusion surrounding the notation used for convolution, with clarifications on the distinction between Stieltjes and Riemann integrals. The discussion concludes with a suggestion to express the convolutions in a symmetric form if the functions share properties akin to probability cumulative distribution functions.
muzialis
Let us write a convolution
$$\int_{0}^{t} A(t-\tau) \mathrm{d}x(\tau)$$ as
$$A \star \mathrm{d}x$$
I would like to write down the expression for the double convolution
$$A \star \mathrm{d}x \star \mathrm{d}x $$
Following the definition I obtain
$$ \int_{0}^{t} \int_{0} ^{t-\tau} A(t-\tau-s) \mathrm{d}x(s) \mathrm{d}x(\tau)$$
Can this be given a more compact form, especially in reference to the upper limit of integration in the inner integral?
I would like to perform the change of variable $$t-\tau = w$$ but unsure as to how to proceed, any hint would be the most appreciated, thanks
Explain what you mean by:
Perhaps you are using some notation known in engineering. However, in the usual mathematical terminology, one convolves two functions and if that's what your talking about, the notation doesn't make it clear if you are using are two functions.
For example if A() is the function defined by A(r) = 3r^2 + r + 1 then what does A * dx mean? In particular what would dx(\tau) be?
Stephen,
many thanks for your input.
I am not using an engineering notation, whatever yo mean by that, I am simply writing the convolution down as a Stijeltes convolution (using Stjeltes instead of Riemann integration), as the notation is more compact.
Under certain technical conditions which can definitely be assumed in the present case, one can write
$$\int_0^{t} A(t-\tau) \frac{\mathrm{d}g}{\mathrm{d}\tau}\mathrm{d}\tau$$
as
$$\int_0^{t} A(t-\tau) \mathrm{d}g(\tau)$$
(formally looking as a change of variable procedure)
Many thanks again, I hope this clarifies and you will help me further.
Your notation needs some words to put it in context.
Which section of the wikipedia article on convolution http://en.wikipedia.org/wiki/Convolution refers to the type of convolution in your notation?
Well, there is no mention in Wikipedia of Stjeltes convolutions (although they are very strongly related to the measure theory approach described in the Section "Measure"), would it help if I edited my question using Riemann integrals notation?
Does you question amount to "How do we do a change of variable in a Stieltjes integral?" I'm not an expert on that topic, but perhaps we can find expositions about how to do it.
Stephen, you are right in pointing out that such notation is confusing. Let me then rephrase my question clearly:
Let us denote a convolution
$$\int_0^{t} A(t-\tau) x(\tau) \mathrm{d}\tau$$
With the notation
$$A \star x$$
$$A\star x \star x$$
Following the definition I could write
$$\int_{0}^{t} \int_0^{t-\tau} A(t-\tau-s) x(s)x(\tau)\mathrm{d}s \mathrm{d}\tau$$
Or, exploiting the associativity property
$$\int_0^{t} A(t-\tau) \int_{0}^{\tau} x(\tau-s)x(s)\mathrm{d}s \mathrm{d}\tau$$
But I would like to write the double convolution using double integrals with the same limits of integration, how can I achieve that (especially in the first of the two expression I wrote down)?
Many thanks
If A(t) and x(t) have properties similar to probability CDFs, you could write the convolution integrals in symmetric form using indicator functions, eg $$\int\int I(t_1+t_2\le t)dA(t_1)dx(t_2)$$ - the three-way version should be fairly straight forward.
  • · Replies 29 ·
