Roberto Pavani
- 353
- 173
- TL;DR
- If spin-polarized silver atoms are allowed to capture electrons between two Stern-Gerlach analyzers, does one expect the beam to remain in the selected branch, collapse predominantly into a non-magnetic component, or split into additional magnetic states? Has this been tested experimentally?
I am trying to understand what standard atomic physics predicts for the following thought experiment, and whether anything similar has ever been performed experimentally.
Silver was used in the original Stern-Gerlach experiment because neutral Ag has a single unpaired 5s valence electron
[Kr] 4d10 5s1
and therefore a well-defined magnetic moment.
Consider the following setup:
SG1 --> select UP branch only
v
electron cloud
v
SG2 (same orientation)
v
transverse electric field
v
detector
The first Stern-Gerlach analyzer (SG1) selects only one branch of the Ag beam (call it "UP").
The selected atoms then pass through a region where electron attachment is assumed to occur with non-negligible probability (regardless of the practical difficulty of achieving this experimentally):
Ag + e− -> Ag−
The beam then enters a second Stern-Gerlach analyzer (SG2) with the same orientation as SG1.
Finally, a transverse electric field is applied before detection so that charged and neutral particles can be distinguished.
My questions are:
1. What would be the dominant electronic state of Ag− formed in such a process?
2. Since the Stern-Gerlach splitting of neutral Ag is dominated by its single unpaired 5s electron, would formation of Ag− be expected to strongly reduce the magnetic moment by filling the 5s shell?
3. What pattern would SG2 be expected to produce?
- only the original UP branch?
- an UP branch plus a central (non-deflected) component?
- additional components corresponding to excited magnetic states?
4. Are there metastable negative-ion states of silver with non-zero magnetic moments that could survive long enough to reach SG2 before radiative decay?
5. After the transverse electric field:
- would a central component be identifiable as Ag− ions?
- would the surviving UP component correspond mainly to neutral Ag atoms that never captured an electron?
If SG2 (and the electric field analyzer) were rotated by 90° relative to the first one, would the surviving neutral Ag atoms split 50/50 while any non-magnetic Ag− component remained undeflected? Would this provide a clean way to distinguish electron attachment from survival of the original spin-polarized beam?
My naive expectation is based on the idea that electron attachment would preferentially produce a closed-shell 5s² configuration, eliminating the single unpaired 5s electron responsible for the magnetic moment of neutral Ag.
If electron attachment occurs with appreciable probability, many atoms might therefore be driven toward a low-energy Ag− configuration with a strongly reduced or vanishing magnetic moment. In that case SG2 might show a dominant central component together with a weaker residual UP component from neutral Ag atoms that never captured an electron.
However, I do not know whether standard atomic physics would actually predict this outcome, or whether there are important effects (electron capture cross sections, selection rules, metastable states, decay lifetimes, etc.) that would lead to a different beam structure.
Even if such an experiment is impractical, I would be interested in the theoretical prediction.
I am mainly interested in the expected beam composition and magnetic signatures, rather than in the practical feasibility of the setup itself.
Has anything similar ever been attempted experimentally, either with silver or another atomic beam?
Any references or qualitative estimates would be greatly appreciated.
[Kr] 4d10 5s1
v
electron cloud
v
v
v
detector
Ag + e− -> Ag−
My questions are:
