DP transmitter level indicator question
  • Thread starter Thread starter frankiee
    Transmitter
In a tank with hot water and steam, a differential pressure (DP) transmitter measures the liquid level based on the pressure difference. When switching from heavy water (specific gravity 1.1) to light water (specific gravity 1.0), the level indication will be affected due to the change in density. The DP transmitter will likely read low with the light water unless recalibrated, as the lighter fluid results in a smaller pressure differential. The wet leg, originally biased for heavy water, will not accurately reflect the new conditions, leading to potential misreadings. Proper calibration is essential to ensure accurate level indication after such a fluid change.
frankiee
Hi
this is an instrumentation and control question
A given tank has hot water process fluid in the bottom and steam as a gas on top.
It has a differential pressure transmiter level with the bottom of the tank
It has a wet leg on the low side of the d\p to control the steam condensate.
If the system was filled with heavy water (sp 1.1) originally and then the whole system was changed to normal light water (sp=1)
What would happen to the level indication if the tank had the same level with both waters?
thanks
It will read low with the light water, right? Unless you re-calibrate it when you change the density of the water.
I don't know the answer but I was thinking it would read high
The DP wet leg would be biased out with the heavy water.
The heavy water would be replaced with lighter water and the dp cell would see more of a delta P. and therefore read more on the gauge then what the tank level really was.
I don't know the answer.
I don't know how they bias the wet leg out so I can't picture it.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 49 ·
  • · Replies 17 ·
