Drag time of terminal velocity?
To determine the time and speed of an object before it reaches terminal velocity, one must solve the differential equation governing its motion, which indicates that the object asymptotically approaches terminal velocity without ever reaching it exactly. The time to reach specific percentages of terminal velocity, such as 50%, 90%, or 99%, can be calculated from this equation. For a rough estimate, one can calculate the time it would take for an object to reach terminal velocity in a vacuum and then apply that to the scenario with air resistance. The shape of the object significantly affects its terminal velocity, as irregular shapes can cause variations in falling behavior. Understanding these dynamics is crucial for accurate predictions of falling objects.
Isawyou0
Hi all!
How can we know the time and speed of the object before it reachs the terminal veocity, it will reach that, but when?
(he's acceleration decreseases right) thanx
If you solve the usual differential equation, the object will never reach the terminal velocity exactly. You can give the time needed until the object reaches 50%, 90%, 99%, ... of the terminal velocity. That will come out of the solution of the differential equation.
If you are just interested in the rough timescale, calculate how long an object without air resistance needs to reach the terminal velocity of the object with resistance.
You could probably get really close as to when and how fast if you're looking at a perfect sphere. Everything else wobbles when it falls, thus it's terminal velocity changes with time.
  • · Replies 22 ·
22K
  • · Replies 19 ·
17K
  • · Replies 24 ·
