Draw free body diagrams for each sphere
This discussion focuses on determining the reaction forces at four contact points (A, B, C, D) for two homogeneous hollow spheres with masses of 1.02 kg and 2.04 kg, positioned in a frictionless chamber 55.98 cm wide. The spheres have radii of 10 cm and 20 cm, respectively. The absence of friction means only normal forces are considered, leading to the formulation of equations based on free body diagrams (FBDs) for each sphere. The key to solving the problem lies in calculating the angle between the line connecting the centers of the spheres and the horizontal/vertical, which allows for the resolution of forces into horizontal and vertical components.
  • Understanding of free body diagrams (FBDs)
  • Knowledge of normal forces and their application in physics
  • Ability to resolve forces into components
  • Familiarity with basic mechanics concepts, including weight and equilibrium
  • Learn how to draw and analyze free body diagrams for multiple bodies
  • Study the principles of static equilibrium in mechanics
  • Explore the concept of normal forces in frictionless systems
  • Investigate the mathematical methods for resolving forces into components
Students and professionals in physics, particularly those studying mechanics, engineers working with static systems, and anyone interested in understanding the dynamics of forces acting on multiple bodies in contact.
frozen7
https://www.physicsforums.com/attachment.php?attachmentid=4225&stc=1
Determine the reaction forces at the four contact points A,B,C,D. The hollow balls which are homogenous and made of the same material have masses of 1.02kg and 2.04kg and the chamber they sit in is 55.98cm wide. Everything is smooth,so that the friction is negligible.
Can anyone help me in this question?
Draw free body diagrams for each sphere. In the absence of frictional forces, there are only normal forces to consider: right at A, left at C, and up at D. The forces at B point along the line connecting the centers of the spheres. Each sphere has weight acting downwards. The hard part is finding the angle between line connecting sphere centers and the horizontal (or vertical). You need to know the size of the spheres. Do you have these? From the two FBDs you will get four equations for the four unkowns. These will easily reduce to two equations because two of the four force magnitudes must be the same, and one must equal the total weight.
opps...I forgot to mention the radius of circles...10 cm and 20cm for each.
since I got the value of radius,I can find out the angle of tbetween the line connect both center and the horizontal/vertical
But...find it for what?
With this angle you can resolve the action-reation pair of forces acting at B into horizontal and vertical components. All the other forces in the problem are either horizontal or vertical. The vector sum of the forces on each sphere must be zero, and that leads to two equations for each sphere (one for horizontal forces and one for vertical forces). That will give you all the equations you need to solve for all four unknown forces.
  • · Replies 25 ·
  • · Replies 19 ·
