Draw layout of circuit using ICs
  • Topic: Engineering
  • Thread starter Thread starter General_Sax
    Circuit
3 replies · 5K views · last reply
General_Sax
What are the ICs you are going to use to breadboard the above logic equation? Draw the layout of the circuit on paper showing all ICs used with proper connections (Pin, Power, and ground). Determine the possible causes of propagation delay in digital circuits.
x
I'm confused at the use of the term ICs. Are they referring to logic gates, like the picture given in the example?
x
I believe they mean to show how to use a 74xx series logic IC to implement the function. Hint -- there is a 74HCxx IC that has 4 AND gates in it, so you could use one of the 4 for the function, and tie off the other 3 as spares.
Look up 74HCxx logic gates, find the quad AND one, and look at the datasheet for the pin numbers for power, ground, and the 4 gates. Then show us how to hook up the pins of the IC to implement the function shown in your problem...
Ok, so I have my logic diagram drawn out. I have a couple questions still:
1) can I have my original I/P (A,B,C,D) leading into both an inverter IC and into AND gate ICs?
2) can I hook up all my ICs to the same power source?
3) this is kind of silly, but can I have wires/lines overlap?
Thanks for the help.
Also, can I have an I/P or O/P "branch" off into multiple/different I/Ps ?
I/P = input
O/P = output
