Drawing a Feynman diagram with limited vertex types
latentcorpse
Consider q3 in this exam:
http://www.maths.cam.ac.uk/postgrad/mathiii/pastpapers/2006/Paper48.pdf
I reckon I can manage a good part of the rest of the question. Unfortunately, I cannot manage the very first bit (drawing the Feynman diagram) and this is preventing me from continuing!
I have attached my best attempt so far...
The problem is in completing the loop. We are only given those to types of vertices and I just cannot get the lines to join up - I end having to add more and more lines and it just gets more and more complicated!
Any advice?
Don't worry too much about the distinction between [tex]\psi[/tex] and [tex]\bar\psi[/tex], since one is the other when changing the direction of time. You can just close the loop without inserting anything more. The Fermion running in the loop is a [tex]\psi[/tex], but from every interaction vertex there is one coming and one going, so you have a [tex]\psi \bar\psi[/tex] at every vertex.
I don't get it. If I close the loop as it is just now using a [itex]\psi[/itex] then that bottom right hand vertex has a [itex]\psi,\psi,\Phi[/itex] at it. Which we clearly can't have because of the interaction terms in the lagrangian!
Can you explain how this works in a bit more detail please?
Thanks!
In reality you don't have [tex]\psi[/tex] and [tex]\bar\psi[/tex] at any vertex, you have a [tex]\psi[/tex] entering and a [tex]\psi[/tex] leaving. But since the [tex]\psi[/tex] entering "comes from the future", from the point of view of this vertex it is a [tex]\bar\psi[/tex]. Take your first vertex, the [tex]\Phi\psi\bar\psi[/tex] one. Assuming time advances from left to right, the upper [tex]\psi[/tex] leaves, advances in time, and so your naming and your arrow are correct. The lower, the one you baptised [tex]\bar\psi[/tex], needs the arrow in the other direction, since it is a [tex]\bar\psi[/tex] leaving from the vertex. If you insist on your arrow direction, however, you must baptise it [tex]\psi[/tex], since a [tex]\bar\psi[/tex] coming from the future (as the arrow shows) is a [tex]\psi[/tex] going into the future.
For the other vertices, the reasoning is the same, if you want one arrow coming in and one leaving (for the [tex]\psi[/tex]'s), they are both [tex]\psi[/tex]'s, but if you want to write [tex]\psi[/tex] and [tex]\bar\psi[/tex], both arrows are leaving.
Note that for the [tex]\Phi[/tex] and [tex]\phi[/tex] this doesn't make any difference, because they are their own antiparticles.
