Drunk Driving (Can I get into school?)
  • Thread starter Roger Wilco
  • Tags
    School
In summary, Warren has two misdemeanor convictions from a decade ago and is worried about how they will be portrayed on his academic application. He suggests contacting an attorney in the jurisdiction (state) where he got the convictions and finding out whether he can possibly obtain a pardon or have his record expunged. He also suggests telling the truth if pressed.
Roger Wilco
30
Okay. Let's try to save the morality speeches for another time. I would rather not talk to much about my past then is necessary. I know I was a retard and have since then given my life an entire makeover.
I am close to thirty years old. I was bagged for drunk driving once at 19 and once at 23. I know, I know. I am lucky no one got hurt (except me, I almost died the second time, but I don't count since it was my own fault).
My problem is this. A year after my close encounter with death I decided to go back to school. I started part time and worked my way up to full time. Finally I have my associates with honors and I am ready to transfer. I filled put the entire common application form and then I got to this:
"Have you ever been convicted of a misdemeanor,felony...If yes explain."
Great. I have two misdemeanors and even worse I have to try to explain them. How the hell do you explain two OUIs? "By the way, on top of my flawless GPA I'm an a$$hole driver with no regard for human life."
That is clearly what they will think of me. I just don't know if I have any options. I hate the thought of lying on the application. I do not think that is a valid option.
I doubt anyone can relate to me right now, but I thought I would ask anyway.
Just stress the fact that you have learned from your mistakes and see returning to school as a way of 'redeeming' yourself.
Everybody derserves a second chance and sometimes even a third chance. In your case, I'd say your deserving of a third chance considering you have cleaned up your act.
Sensible people will not continue to punish you for things you did a decade ago.
- Warren
Due to the fact that these events happened over half a dozen years ago, I don't think it will hurt you. It certainly won't help you, but as chroot said, any understandable person should realize that you've grown up and are into adulthood.
It seems odd that they are asking about a misdemeanor. I wasn't aware that schools actually did background checks.
CS
why not? i might not give you a drivers license but i don't see why you wouldn't qualify for an academic degree.
I agree. I have no idea what drunk driving has to do with your academics at school. Yeah you may have failed in life in that aspect, but it has nothing to do with your education.
Correct. As others have said, your DUI's probably will not have an effect on your chances of admission, but lying about them definitely can have an effect if they find out about it, and your convictions are on the public record. So I would answer "yes" and be prepared to explain it.
I don't know about the US, I suspect it's far from the case, but in the UK depending on the offence, you don't have to mention it if it's 6 years past for a job application as the CPS check only covers that period, let alone a decade.
But the US is different, and I suspect harsher. Although, look at Paris Hilton?
Schools in the US typically ask about criminal records for two reasons: (1) they face liability if you later harm another student; and (2) persons with criminal records are barred from some programs, e.g., early childhood education, pharmacy, etc.
I suggest you contact an attorney in the jurisdiction (state if you're US) where you got the convictions and find out whether you can possibly obtain a pardon or have your record expunged. Then, you need also to find out whether you have to divulge the convictions if you have a pardon or expungement.
Barring that, tell the truth. If pressed, use the "I found Jesus" explanation. But, accept that some doors will be closed to you all your life.
It isn't. As jtbell said, geting caught lying about those DUI's will put you in a worse situation. I would mention the offenses and explain yourself and explain how you have changed. Think of it this way. Talking about the DUI's on you application and explaining your position shows that you are accepting responsibility for your actions and made successful effort to change for the better. Good luck!
The "explain" part means write down "DUI," it doesn't mean explain why you got a DUI (just in case that isn't clear). I'm sure you're not the only applicant with dings in the past...they want to make sure that someone with a mile long rap sheet for burglary or rape isn't going to be living in dorms though. If at some point you do get asked about it, all you need to tell anyone is pretty much what you've shared here...you were young and stupid, the second DUI nearly killed you, and that woke you up to be more serious about your future, which you started off doing by getting your Associate's Degree, and your grades speak for your seriousness in changing your life for the better.
1. What is drunk driving and why is it dangerous?
Drunk driving is the act of operating a vehicle while under the influence of alcohol. It is dangerous because alcohol impairs judgement, reaction time, and motor skills, making it difficult for a driver to safely operate a vehicle and increasing the risk of accidents.
2. Can I get into school with a DUI on my record?
It depends on the specific school and their admissions policies. Some schools may have a strict policy against admitting students with a DUI on their record, while others may consider the circumstances and overall character of the applicant. It is important to disclose any DUI convictions on your application and be prepared to explain the situation and show that you have learned from your mistake.
3. How does a DUI affect my driving record?
A DUI conviction will typically result in points on your driving record, which can lead to higher insurance rates and potential license suspension. In some cases, it may also result in the revocation of your driver's license. Additionally, a DUI conviction will remain on your record for several years and can be considered during background checks for jobs or other opportunities.
4. What are the consequences of getting caught driving under the influence?
The consequences of a DUI conviction vary depending on the state and the individual's prior record. They can include fines, license suspension, community service, and even jail time. In addition to legal consequences, a DUI can also have a significant impact on one's personal and professional life.
5. Can I refuse a breathalyzer or sobriety test when pulled over for suspected drunk driving?
It is within a person's rights to refuse a breathalyzer or sobriety test, however, this may result in additional consequences such as immediate suspension of your driver's license. Additionally, refusing a test can be seen as an admission of guilt and may make it more difficult to defend against a DUI charge in court. It is important to consult with a legal professional before making a decision to refuse a test.
  • STEM Academic Advising
