How quickly do ocean spray droplets dry into solid salt particles?
The discussion focuses on the drying process of ocean spray droplets into solid sodium chloride (NaCl) particles. Key variables influencing this process include droplet size, salt concentration, relative humidity, air speed, and temperature. It is established that sodium chloride is hygroscopic, absorbing moisture when relative humidity exceeds 75%. The drying process occurs when humidity falls below this threshold, particularly in heated air environments such as ventilation ducts.
  • Understanding of hygroscopic materials and their properties
  • Knowledge of aerosol dynamics and sea spray formation
  • Familiarity with the impact of environmental conditions on evaporation rates
  • Basic principles of thermodynamics related to temperature and humidity
  • Research the effects of droplet size on evaporation rates in aerosols
  • Study the role of relative humidity in the hygroscopic behavior of sodium chloride
  • Explore measurement techniques for evaluating drying rates of sea spray droplets
  • Investigate the impact of air speed on the drying process of aerosols
Atmospheric scientists, environmental researchers, and professionals studying aerosol behavior and its implications on climate and air quality.
Peter Hessellund
When a bubble in the ocean bursts water drops are thrown into the air. How fast do these water drops dry out creating solid salt particles? There must be a formula for calculating this and I am guessing that the following variables must figure in the formula:
- Droplet size
- Salt concentration (Lets just assume that is is NaCl)
- Relative humidity
- Air speed around the particle
- Temperature
Or maybe someone just made a measurement.
I doubt they ever do dry out ... sodium chloride is hygroscopic . It absorbs moisture from the atmosphere when the relative humidity is above 75%
But they must dry out when the humidity is below 75% In my case when the air enters a ventilation duct where the air is heated slightly.
Look under "sea spray", or "aerosols", and see if you can find out some information for your inquiry.
  • · Replies 28 ·
10K
  • · Replies 28 ·
