Dynamic allocation problem with linked lists
3 replies · 2K views
gruba
I need to create data structure which contains three linked lists that are connected to one root node.
-Data structures
I can't find what is wrong with the following code:
Code:
#include<stdio.h>
#include<stdlib.h>
typedef struct node
  struct node *next;
  int y;
}NODE;
typedef struct root
  struct node *first;
  struct node *middle;
  struct node *last;
  int x;
}ROOT;
ROOT *form_root(int x)
  ROOT *new_root=(ROOT *)malloc(sizeof(ROOT));
  new_root->first=new_root->middle=new_root->last=0;
  new_root->x=x;
  return new_root;
void add_in_list(NODE *list,int y)
  NODE *new_node=(NODE *)malloc(sizeof(NODE));
  new_node->y=y;
  new_node->next=NULL;
  if(list == 0)
  list=new_node;
  else
  return ;
ROOT *add(ROOT *root,int x)
  if(root==0)
  return form_root(x);
  if(x < root->x)
  add_in_list(root->first,x);
  else
  if(x > root->x)
  add_in_list(root->last,x);
  else
  add_in_list(root->middle,x);
  return root;
int erase_from_list_(NODE *node,int y)
  NODE *p=node->next;
  if(p==0)
  return 0;
  node->y=p->y;
  node->next=p->next;
  free(p);
  return 1;
ROOT *erase(ROOT *root, int x)
  if(root==0)
  return 0;
  else if(x < root->x)
  root->first=erase_from_list_(root->first,x);
  else if(x > root->x)
  root->last=erase_from_list_(root->last,x);
  else if(x==root->x)
  root->middle=erase_from_list_(root->middle,x);
  else
  return 0;
  return root;
void sort_list(NODE *head)
  for(;head && head->next;head=head->next)
  NODE *min=head,*p;
  for(p=head->next;p;p=p->next)
  if(min->y > p->y)
  min=p;
  if(min!=head)
  int temp=head->y;
  head->y=min->y;
  min->y=temp;
void sort(ROOT *root)
  sort_list(root->first);
  sort_list(root->middle);
  sort_list(root->last);
void print_list(NODE *head)
  while(head)
  printf("%d",head->y);
  head=head->next;
void print(ROOT *root)
  print_list(root->first);
  print_list(root->middle);
  print_list(root->last);
int main()
  ROOT *root=0;
  int array[][3]={{0,1,2},{3,4,5},{12,7,8}};
  int i;
  for(i=0;i<3;i++)
  root=add(root,*array[i]);
  int num;
  printf("enter the number to be removed:");
  scanf("%d",&num);
  root=erase(root,num);
  sort(root);
  NODE *head=0;
  print(head);
  return 0;
Could someone help?
on Phys.org
-Data structures
<omitted>
Could someone help?
A clue as to what's wrong would be helpful. Does your code compile? If not, what compiler and/or linker errors are you getting (including the line number where the error occurs)? Does your code compile, but produce run-time errors? Does your code run, but produce incorrect results?
We're happy to help, but please give us some information to go on.
Just looking at this function:
Code:
  new_root->first=new_root->middle=new_root->last=0; ********* Really look at this line.
  new_root->x=x;
  return new_root;
Can you see why your code is wrong? It should read like so:
Code:
ROOT *new_root = (Insert a new root here);
new_root->first = (Insert a new node here);
new_root->second = (Insert a new node here);
new_root->third = (Insert a new node here);
new_root->x = x;
The first, second and third fields are not integers you can set to zero. They are actually nodes with a next and y field.
Look at your code more.
Code:
  new_root->x=x;
  return new_root;
Code:
new_root->x = x;
The OP's first line of code uses malloc() to allocate heap memory for a new node. This is the appropriate thing to do, not "insert a new root here" as you wrote.
Correct, they are not integers, but the OP is initializing these pointers to NULL What the OP has done is not the best way to do things, but I get what the intent is.
This is also good advice for you, @Zondrina.
I'm waiting for the OP to give us more information about what is wrong with the posted code.
