Uncovering the Constant C: Equal Mass Equals Equal Energy?
All matter with equal rest mass has the same energy when at rest, meaning 1 kg of water and 1 kg of uranium possess identical mass energy. However, for matter in motion, the relationship changes, and the correct formula is E² = m²c⁴ + p²c², where p represents momentum. This indicates that objects with the same mass but different velocities will have different energy levels. Therefore, while rest mass equates to equal energy, motion introduces variability in energy based on momentum. Understanding these distinctions is crucial in discussions of mass-energy equivalence.
Adam Rifai
Since C is constant, so all matter of equal rest mass have the same E ?!
e.g. an equal rest mass of water and rest mass of Uranium have the same energy ?
Yes, the mass energy related to 1 kg of water is the same as the mass energy in 1 kg of uranium.
Likes Adam Rifai
Assuming the matter is at rest, yes. For matter in motion, ##E = mc^2## is not correct; the correct formula is ##E^2 = m^2 c^4 + p^2 c^2##, where ##p## is the momentum. So pieces of matter with the same ##m## but different ##p## (because they are moving at different speeds) will have different ##E##.
Likes Adam Rifai
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 19 ·
  • · Replies 36 ·
  • · Replies 26 ·
  • · Replies 102 ·
  • · Replies 55 ·
