Earth and Moon (Acceleration of Gravity)
The discussion revolves around calculating gravitational acceleration and weight on the Moon compared to Earth. The gravitational acceleration on the Moon is determined to be 1.62 m/s², leading to a weight of 10.568 N for an object that weighs 64 N on Earth. The user initially miscalculated the distance in Earth radii needed for the object to weigh the same on the Moon, arriving at 2.461 Earth radii. It was clarified that this calculation mistakenly included the Earth's radius instead of measuring from its surface. After adjusting the calculation by subtracting one radius, the user confirmed they found the correct answer.
physics817
The moon has a mass M = 7.36e+022 kg and an average radius R = 1740 km.
for part a)I solved for the gravitational acceleration on the surface of the moon= 1.62 m/s^2
An object on Earth weighs 64 N.
b) What is the weight of this same object on the moon? Answer: 10.568 N
I am stuck on part c. of the problem...
c) How many Earth radii must this same object be from the surface of the Earth if it is to weigh the same as it does on the surface of the moon?
g= GMe/Re^2
What I did was, I tried to use the g(moon)= 1.62= GMe/(nRe)^2
where G= 6.67e-11
Me= 5.97e24
Re=6.37e6
And solved for n= number of Earth radii= 2.461, but that isn't correct.
Can someone tell me what I did wrong? Thank you.
[...]n= number of Earth radii= 2.461, but that isn't correct.
It seems that what is wrong is that you're including the radius of the Earth itself, where as the question asks how many radii is it from the surface of the Earth and not its centre.
The Bob
is that the right way to solve the problem then? Since it asks for how many Earth radii from the surface of the earth..and I included one radius of the eart in my answer..all I do is minus 1 to get the answer?
Thanks.
I can't see anything wrong with your method apart from the fact it includes the radius of the Earth itself rather than from the surface. I believe simply taking away 1 will give you the correct solution. If not, let us know.
The Bob
I did get the correct answer after subtracting one..I was unsure as to whether the problem-solving was correct of if I got to the answer by chance. Thank you very much for your help!
Cool, no problem. Glad to help. All the best,
The Bob
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
