Earth Core Temperature: Causes & Impact
The Earth's core generates its own energy primarily through the processes of latent heat release during the growth of the inner core and gravitational energy from the freezing of iron and nickel. The core temperature, approximately 4000 degrees Celsius, is maintained over billions of years due to the Earth's size and the poor heat conductivity of rock. While most geophysicists agree that radiogenic heating is minimal in the core, the core does contribute to mantle heating and sustains the Earth's magnetic field through convection. The heat flux across the core-mantle boundary is debated, with estimates ranging from 2 to 17 terawatts. The discussion also touches on the potential for extreme pressure and heat at the Earth's center, questioning the implications for tectonic activity and the Earth's structural integrity.
Stephanus
Dear PF Forum,
Does the Earth core produces its own energy?
If it is true, how? Radioactive decay? Gravity?
Earth core temperature is around 4000 Celcius. Almost like the sun surface temperature.
How can that temperature kept for 4 billions of year?
Can the temperature heat the mantle and Earth surface through convection heat transfer?
The Earth is big, and rock isn't a very good conductor of heat.Does the Earth core produces its own energy?
Yes, it does. The Earth's inner core is growing. To melt something, you need to supply heat. Melting is an endothermic process. The opposite, freezing, is an exothermic process. The growth of the inner core releases latent heat. Gravity also plays a role. This freezing selectively concentrates iron and nickel in the inner core, leaving lighter impurities in the molten outer core, thereby releasing gravitational energy.
Most (but not all) geophysicists are of the opinion that there is very little radiogenic heating in the Earth's core. The four isotopes responsible for almost all of the Earth's radiogenic heating are uranium 238, uranium 235, thorium 232, and potassium 40. Chemically, uranium, thorium, and potassium are lithophile elements, which means they are found in rock (not in the core). Moreover, they are incompatible elements, which means they are concentrated in the Earth's crust. Those elements should be very strongly depleted in the Earth's core. (Some geophysicists think there may be some potassium 40 in the Earth's outer core.)Can the temperature heat the mantle and Earth surface through convection heat transfer?
The Earth has a magnetic field. Two things are needed for this: A rotating fluid that conducts electricity, and convection in the fluid (i.e., a heat flux through the fluid). The Earth's core has to be heating the mantle; if it wasn't, we wouldn't have a magnetic field. Mars has a liquid inner core but doesn't have a magnetic field; this is presumably because Mars has a stagnant lid rather than plate tectonics.
The amount of heat flux needed to sustain the magnetic field is subject to debate. Different geophysicists agree to disagree. Most think it is about 5 terawatts across the core-mantle boundary. Others think less is needed. How much heat actually flows across the core-mantle boundary is also subject to debate. Most geophysicists think it is between 5 and 15 terawatts. Some argue for a smaller number, others for an even bigger number, making the range 2 to 17 terawatts. As an interested bystander, those widely varying numbers means that a lot more work needs to be done.
Likes Stephanus and praveena
Is there is any possibility when the pressure & heat at the centre of Earth reaches it's most peak value? And this results the Earth to broken into pieces? Orelse only the tectonic plates may have a large movement even when the core reaches it's maximum pressure & heat?
"Peak value"? And what would that be? 1 million kelvin? Well, if the core of the Earth reaches that high, a 1000 km sphere at 1 million kelvin, it will surely destroy the earth. But how can it reach that heat? And you haven't defined what is the "peak value"
Likes praveena
Indonesia evacuates stranded climbers after Semeru volcano erupts https://www.reuters.com/business/environment/indonesia-evacuates-stranded-climbers-after-semeru-volcano-erupts-2025-11-20/ https://www.bbc.com/news/videos/clyzy88l87no Indonesia’s Mount Semeru erupts, blanketing villages with ash and prompting evacuations https://apnews.com/article/indonesia-volcano-mount-semeru-east-java-004472fe274828ceac7c4d48ddd7abc6 More than 170 people rescued off Mount Semeru after eruption as 1,000...
  • · Replies 42 ·
  • · Replies 25 ·
14K
9K
9K
