Earth's position relative to the Sun.
The discussion centers on the Earth's orbital dynamics in relation to the Sun's transition into its Red Giant phase. Participants clarify that while the Sun's expansion will not significantly alter the gravitational attraction due to its mass remaining constant, the Sun is losing mass over time, which will cause the Earth to gradually spiral outward. Ultimately, despite these changes, the Earth is still expected to be engulfed by the Sun during its Red Giant phase. Key concepts include gravitational attraction, mass loss, and orbital dynamics.
  • Understanding of gravitational attraction and its dependence on mass and distance
  • Knowledge of stellar evolution, specifically the Red Giant phase
  • Familiarity with orbital mechanics and dynamics
  • Basic concepts of solar mass loss and its effects on planetary orbits
  • Research the effects of stellar mass loss on planetary orbits
  • Study the process of stellar evolution, focusing on the Red Giant phase
  • Learn about gravitational dynamics in multi-body systems
  • Explore the implications of solar wind on planetary atmospheres and orbits
Astronomers, astrophysics students, and anyone interested in understanding the long-term effects of stellar evolution on planetary systems.
Khan Wolf
Would someone please correct my train of thought on this?
I understood that the Earth's position in the Solar System is related to the gravitational attraction between the Earth and the Sun. If this thought is correct, then when the Sun enters its Red Giant phase, the Earth should be pushed back into Mars's orbital path. Thoughts...corrections...help!
Astronomy news on Phys.org
HI Khan Wolf! :smile:
Khan Wolf said:
… the Earth's position in the Solar System is related to the gravitational attraction between the Earth and the Sun. If this thought is correct, then when the Sun enters its Red Giant phase, the Earth should be pushed back into Mars's orbital path.
No, the expansion of the Sun will make almost no difference to the Earth's orbit …
once you get into "empty space", the gravitational field of a star depends on its mass, not on its size. :wink:
When the Sun enters its Red Giant phase, the Earth should be pushed back into Mars's orbital path
The distance between the Earth and Sun will become less and less so the gravitationional attraction will become greater and greater. The Earth would therefore be engulfed by the Sun.
Gravitational force is pretty much a function of distance to the Sun's center of mass, not its surface. Assuming the Sun's mass doesn't change, the gravitational attraction between the Sun and the Earth will be pretty much the same whether the Sun is a red giant whose radius is just shy of 1 AU or a tiny white dwarf.
However, the Sun's mass is not constant. It is losing mass due to fusion in the Sun's core and solar wind from the Sun's surface. The Earth will (and is) spiral out a bit from the Sun. The change is rather small, however, and most likely will not save the Earth from being engulfed when the Sun enters its red giant phase.
While this is of course true, when the Sun enters its red giant phase not just expansion takes place! Realistically, the sun will begin to shed an appreciable portion of its mass, both during the transition and once it becomes a red giant due to increased stellar winds. So the net effect of the sun moving off the main sequence is an increase in orbital radius.
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 27 ·
