Easy complex analysis question
6 replies · 2K views
Nikitin
[solved]Easy complex analysis question
Hi. In the complex plain, since y = 0 (in z=x+iy) at the x axis, shouldn't the following be true? :
##y=0##
[tex]\int_{-\infty}^{\infty} \frac{\cos(ax)}{x^2+2x+5} dx = \int_{-\infty}^{\infty} \frac{e^{iaz}}{z^2+2z+5} dz = \int_{-\infty}^{\infty} f(z) dz[/tex]
Or does it only go like this:
##y=0##
[tex]\int_{-\infty}^{\infty} \frac{\cos(ax)}{x^2+2x+5} dx = Re(\int_{-\infty}^{\infty} \frac{e^{iaz}}{z^2+2z+5} dz)= Re( \int_{-\infty}^{\infty} f(z) dz)[/tex]
I am asking because I need to find the value of the integral ##\int_{-\infty}^{\infty}\frac{\cos(ax)}{x^2+2x+5} dx## using the residue theorem, but I don't know whether I need to use the residue of ##Re(\int_{-\infty}^{\infty} f(z) dz)## or ##\int_{-\infty}^{\infty} f(z) dz##. The problem is that if I use the latter, my logic seems coherent but I get a residue which has both a real and imaginary part, which hints that I should find the residue of the former instead.
In fact,both are wrong!
This is how it should be:
[itex] \int_{-\infty}^{\infty} \frac{\cos{ax}}{x^2+2x+5}dx=Re (\int_{-\infty}^{\infty} \frac{e^{iax}}{x^2+2x+5}dx)[/itex]
Could you please explain:
1) why my equations are wrong
2) why yours is right
EDIT: oops I forgot to specify that y=0 for BOTH of those two integrals. They were both integrated along the x-axis.
No, how could this be true since ##\cos ax \ne e^{iax}##?
but it's true if y =0, isn't it? sorry I forgot to specify this condition in the OP. All the integrals are evaluated on the real x-axis.
No. Euler's formula tells you that ##e^{iax} = \cos ax + i\sin ax##. For complex z, you have ##e^{ia(x+iy)} = e^{-y}e^{iax}##, which is equal to ##e^{iax}## when y=0, so you still have a problem.
oh crap I forgot about the ##i## infront of the ##az## (i've been cramming 70-80 hours a week now in preparation for the exams, duno if this is a good excuse). OK, I see the problem now,t hx
