Easy Integration of Sinusoidal Functions with Multiple Integrals
  • Thread starter holezch
    Integration
5 replies · 2K views · last reply
holezch
F(x) = sin ([tex]\int[/tex]0 to x sin ( [tex]\int[/tex] 0 to y sin^3(u) du) dy )
find F'(x)
FTC
Is the answer
cos ([tex]\int[/tex]0 to x sin ( [tex]\int[/tex] 0 to y sin^3(u) du) dt ) sin( [tex]\int[/tex] 0 to x sin^3(u) du) dy ) sin^3(x)?
because when you differentiate the integral, the function you get becomes with respect to the boundary variable and so the last terms become with respect to x and I have to differentiate them as well?
([tex]\int[/tex]0 to x sin ( [tex]\int[/tex] 0 to y sin^3(u) du) dy ) this becomes sin ( tex]\int[/tex] 0 to x sin^3(u) du), then since the integral in the argument is with respect to x, I must differentiate that as well to get sin^3(x)
thanks
I doubt anyone can make sense of that. Use a little tex to make it readable. For example, you do an integral like this:
[tex]\int_{lower limit here}^{upper limit here} integrand\ dx [/itex]<br /> <br /> To see what I did just click on it. You can copy and paste it and use it to post your question so we can read it.[/tex]
thanks, I didn't know how to do that
anyway, I'm looking for the derivative of:
[tex] F(x) = sin(\int_{0}^{x} sin(\int_{0}^{y} sin^3(u)\ du)\ dy )[/tex] I'm pretty sure that it comes out to be: [tex] F'(x) = [cos(\int_{0}^{x} sin(\int_{0}^{y} sin^3(u)\ du)\ dy ) \ dx] sin(\int_{0}^{x} sin^3(u)\ du) sin^3(x)[/tex]
But I'm not 100% clear about the steps. Why do I have to keep differentiating after I differentiate [tex](\int_{0}^{x} sin(\int_{0}^{y} sin^3(u)\ du)\ dy )[/tex] (from the chain rule)
Is it because when I differentiate the expression, [tex]sin(\int_{0}^{y} sin^3(u)\ du)\ dy )[/tex], it is evaluated at x and so I must differentiate that expression? (since I am differentiating with respect to x)
thank you
You have an extra dx at the end of your F(x) that shouldn't be there.
Call
[tex] <br /> g(x)= \int_{0}^{x} sin(\int_{0}^{y} sin^3(u)\ du)\ dy[/tex]
so your F(x) = sin(g(x)) and F'(x) = cos(g(x)) g'(x) by the chain rule.
Now by the fundamental theorem of calculus to get g'(x) you simply write the integrand in g(x) with the dummy variable y replaced by x:
[tex]g'(x) = sin(\int_{0}^{x} sin^3(u)\ du)[/tex]
Put those together; I think it is a bit different than what you wrote. It's late and I'm a little sleepy so check it. :zzz:
thanks, I noticed the extra dx. I left it there by accident after copying and pasting the integral latex code
by the chain rule it should be F'(x) = cos(g(x) )g'(x), but how come the answer has sin^3(x) at the end? is it wrong? (I got this answer from someone's notes, refer to post #3)
thanks
