Easy question calculating uncertainty
  • Thread starter Thread starter LBRRIT2390
    Uncertainty
LBRRIT2390
What is the mass uncertainty, [tex]\delta[/tex]m = m+ - m, of the particle?
m = [tex]\frac{R*|q|*B}{v}[/tex]
where
R = (6.4[tex]\pm[/tex]0.1) cm (convert to meters so 0.064[tex]\pm[/tex]0.001)
|q| = 1.6*10-19
B = (2.50[tex]\pm0.02[/tex]) T
v = (5.25[tex]\pm0.04[/tex])x107
I figured out that m = m = 4.88*10-28kg
When I tried to find the upper limit I got 4.95x10-28
and the lower limit, 4.80x10-28
My professor's answer sheet says that m+ = 5.03 x 10-28 kg
and [tex]\delta[/tex]m = 0.2x10-28 kg.
First of all, I don't know how he determined that [tex]\delta[/tex]m = 0.2x10-28 kg. Can someone help me?
Second of all, if m = (4.88*10-28kg) and [tex]\delta[/tex]m = 0.2x10-28 kg then shouldn't m+ = 5.08 x 10-28 kg?? NOT 5.03 x 10-28 kg??
Technically, the correct formula from error analysis is
[tex]\delta f(x_1, \cdots, x_n) = \sqrt{ \sum_{i = 1}^n \left( \frac{\partial f(x_1, \cdots, x_n)}{\partial x_i} \delta x_i \right)^2 }[/tex]
where [itex]\delta x_i[/itex] is the uncertainty in xi.
So in this particular case, you would get
[tex] (\delta m)^2 = <br /> \left( \frac{\partial}{\partial R} \frac{R|q|B}{v} \right)^2 (\delta R)^2 + <br /> \left( \frac{\partial}{\partial |q|} \frac{R|q|B}{v} \right)^2 (\delta |q|)^2 + <br /> \left( \frac{\partial}{\partial B} \frac{R|q|B}{v} \right)^2 (\delta B)^2 + <br /> \left( \frac{\partial}{\partial v} \frac{R|q|B}{v} \right)^2 (\delta v)^2.[/tex]
Sorry, you can disregard my earlier post. I missed that you posted in precalculus and using a much simpler formula.
Note that to find the upper bound, you have to plug in the extreme values, such that the result for m will be as large as possible.
There is a variable v in the denominator. That means that to make m large, you should make v small. For example, 1/1000 is smaller than 1/10.
In other words, you shouldn't use 5.29 x 107 for the extremal value of v, but 5.51 x 107.
