Eccentrically loaded foundation (Meyerhoff theory)
  • Thread starter dss975599
    Theory
dss975599
For this question , I tried to use L' = L -2e and B '= B , i ended up getting different final answer when i use L ' = L , B'= B -2e
In the notes , we can see that if the eccentricity were in the direction of length of the foundation , L '= L-2e , and B'= B ...
But , in this question , I am not sure whether the eccentricity were in the direction of length of the foundation or the width of foundation
Why can't I use L' = L -2e = L-2(0.25) = and B '= B to determine the answer. Since this question is a square foundation , I'm confused whether to use L' = L -2e = L-2(0.25) = and B '= B or L ' = L , B'= B -2e ... Can anyone explain please ?
  • Diagram of a square footing under a vertical load of 100,000 lb and moment of 25,000 lb.ft, with a 4 ft soil layer (gamma-d 100 lb/ft3, C 0.00, phi 30) above a second layer (gamma-sat 120 lb/ft3, C 0.00, phi 30) and width B marked.
  • Handwritten-style worked solution for a bearing capacity problem: q_u = cN_c F_cs F_cd F_ci + qN_q F_qs F_qd F_qi + 0.5γB'N_γ F_γs F_γd F_γi, with shape, depth and inclination factors, leading to B = 6.5 ft from 600,000/(B²−0.5B) = −2451.2/B² + 11334.571/B + 11542.208 + 387.072B.
  • Page of a textbook titled Ultimate Bearing Capacity Under Eccentric Loading—One-Way Eccentricity, with a heading Effective Area Method (Meyerhoff, 1953) and introductory text describing a step-by-step procedure.
I think this goes back to the definitions of B and B'.
B and B' are always the shorter lengths of the plan dimensions of the foundation.
So, although you compute L'= L - 2e, L' will now be smaller than B'=B=L. So automatically, we reassign B' = L-2e and L'=B.
Let's say my original L = 3.2m , B = 3.0m , e= 0.2m, , the eccentricity is in the direction of L ... So , L ' = L-2e = 3.2-2*0.2 = 2.8m , B ' = B = m ...So, we need to reassign old L' = B' = 2.8 ? whereas the old B' = 3 = L' ?
In this case: L' = 2.8 m and B'= 3.0 m , but remember that B' must be smaller of the two. So, L'= 3.0m and B' = 2.8 m
