Efficiency - how to get the maximum efficiency in a circuit?
2 replies · 1K views
alexmath
efficiency -- how to get the maximum efficiency in a circuit?
I don't quite understand how to get the maximum efficiency in a circuit.
Exemple.
4 Volts and 2.0Ω will produce 8 watts with a current of 2.0 amps.
5 Volts and 3.1Ω will produce 8 watts with a current of 1.6 amps.
There are infinitely ways to do so. Also we have an led which has to be connected.
P=UI=I^2*R=U^2/R
My intuition says that the first one is more efficient, but the battery will drain faster. I really want to know how to mix this information together for my circuit.
More details are required.
Both are 100% efficient if the wanted output is heat.
Both are 0% efficient if the wanted output is light (because there is no light bulb or LED in the circuit as described so far).
