Graduate Are Eigenvalues of Hermitian Integer Matrices Always Integers?
  • Thread starter Thread starter LagrangeEuler
    Eigenvalues Matrix
Eigenvalues of Hermitian matrices with integer entries are not guaranteed to be integers. The determinant equation, det(A - λI) = 0, indicates that polynomials with integer coefficients can have non-integer roots. This raises the possibility that while the matrices are Hermitian, their eigenvalues may not necessarily be integers. A counter-example is suggested as a potential way to explore this further. The discussion emphasizes the need for more investigation into the properties of such matrices and their eigenvalues.
LagrangeEuler
If matrix has integer entries and it is hermitian, are then eigenvalues also integers? Is there some theorem for this, or some counter example?
What do you think? How do you find eigenvalues of a matrix?
From ##det(A-\lambda I)=0##. Polynomial with integer coefficients does not need to have integer roots. So I suppose that this is not the case. But here matrices are hermitian so I am not sure. :)
LagrangeEuler said:
From ##det(A-\lambda I)=0##. Polynomial with integer coefficients does not need to have integer roots. So I suppose that this is not the case. But here matrices are symmetric so I am not sure. :)
I would think that would be the motivation to look for a simple counter-example.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 33 ·
