Eigenvalues and operators, step the involves switching and substitutin
6 replies · 1K views · last reply
rwooduk
Operator C = I+><-I + I-><+I
Wavefunction PSI = Q I+> +V I->
C PSI = Q I-> + V I+>
note the I is just a straight line (BRAKET vectors), the next step is where I get confused, p is subbed in and the ket vectors switch places...
C PSI = pQ I+> + pV I-> <---- why??
therefore
V = pQ and Q = pV
which gives p^2 Q = Q therefore p = +/- 1
why can p be subbed in and the ket vectors switch around, i.e. I-> no longer with Q and I+> no longer with V
thanks
What is p? What are you even trying to do? What source of information are you using?
Hi, I am reviewing last semesters quantum mechanics, the complete question is:
Determine the eigenvalues of the operator C = I+><-I + I-><+I. You may use PSI = Q I+> + V I-> as an eigenvector.
so p would be the eigenvalues of the operator C which are +1 and -1
the solution introduces p to C PSI = Q I-> + V I+> by switching the ket vectors around and putting p with each term, I don't understand why this is.
thanks for the reply
therefore
V = pQ and Q = pV
thanks
Please don't write I. There's a vertical line on the keyboard that you can use. Or you can copy and paste this one: |
I assume that Q and V are just numbers. What is p and how did it enter the calculation?
Oh wait, p is the eigenvalue, right? Then by definition of eigenvalue and eigenvector, you have ##C|\psi\rangle =p|\psi\rangle##. Now you can just use the definition of ##|\psi\rangle## to get
$$C|\psi\rangle =p|\psi\rangle =p(Q|+\rangle+V|-\rangle)=pQ|+\rangle+pV|-\rangle.$$ Since you already know that
$$C|\psi\rangle=Q|-\rangle+V|+\rangle,$$ this implies that pQ=V and pV=Q.
oh dear I missed something in the solution:
Recall the eigenvalue equation: C |PSI> = p |PSI>
that would explain where the p comes from, but it doesn't explain why the ket vectors switch around... or does it?
Yes Q and V are just numbers.
Apologies on the I.
Apologies on the I.
If p is the eigenvalue, then by definition of eigenvalue and eigenvector, you have ##C|\psi\rangle =p|\psi\rangle##. Now you can just use the definition of ##|\psi\rangle## to get
$$C|\psi\rangle =p|\psi\rangle =p\big(Q|+\rangle+V|-\rangle\big)=pQ|+\rangle+pV|-\rangle.$$ Since you already know that
$$(pQ-V)|+\rangle +(pV-Q)|-\rangle=0.$$ Since the basis vectors are linearly independent, this implies that pQ-V=0 and pV-Q=0.
Ahhh I see now, that's great! Thanks very much for your time, really appreciated!
