What are the eigenvalues and eigenvectors of matrix A = [2 2; 3 1]?
The discussion revolves around finding the eigenvalues and eigenvectors of the matrix A = [2 2; 3 1]. Participants are exploring the mathematical concepts related to eigenvalues and eigenvectors, including the characteristic equation and the implications of the results obtained.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the process of calculating eigenvalues and eigenvectors, with some attempting to derive the eigenvectors corresponding to the eigenvalue 4. There is a focus on the relationship between eigenvalues and their associated eigenvectors, including the notion that any scalar multiple of an eigenvector is also an eigenvector. Questions arise regarding the choice of specific values for the eigenvector components and the verification of results.
The discussion is ongoing, with participants providing insights and corrections to each other's work. Some have pointed out potential errors in calculations and the need to verify results by substituting eigenvectors back into the original matrix equation. There is an exploration of multiple interpretations regarding the eigenvectors corresponding to the eigenvalue -1, and the conversation remains productive without reaching a consensus.
Participants are navigating through the implications of a typo in the matrix and its effect on the calculations. The discussion includes the need for clarity on the definitions and properties of eigenvalues and eigenvectors, particularly in the context of linear dependence among rows of the matrix.
fuzzyorama
Eigenvalues & Eigenvectors !SOLVED!
Find the eigenvalues and eigenvectors of matrix
A = \left( \begin{array}{cc} 2 & 2 \\ 3 & 1 \end{array} \right)
Ax = \lambda x
Solving
\left\vert \begin{array}{cc} 2 - \lambda & 2 \\ 3 & 1 - \lambda \end{array} \right\vert
I get the eigenvalues \lambda = -1, 4
When \lambda = 4
\left( \begin{array}{cc} -2 & 2 \\ 3 & -2 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 4\left( \begin{array}{c} x \\ y \end{array} \right)
Then I get these equations -2x + 2y = 4x \mbox{~and~} 3x -3y = 4y
From the first equation, y = 3x. So is
x\left( \begin{array}{c} 4 \\ 12 \end{array} \right) the eigenvector?
Ax = \lambda x
Solving
When \lambda = 4
That will certainly work. But remember that the set of all eigenvectors, corresponding to a given eigenvalue, form a subspace- there is no such thing as the eigenvector, there are an infinite number of them. Any multiple of an eigenvector is also an eigenvector. Here you got y= 3x. Any reason for then taking x= 4? The fact that the eigenvalue is 4 (if that's where you got the "4") does not imply that x must be 4. I might be inclined to take x= 1 so that y= 3(1) and the eigenvector is
\left(\begin{array}{c}1 \\ 3\end{array}\right)
or you might divide that by its length, \sqrt{10} to get a unit length eigenvector,
\left(\begin{array}{c}\frac{1}{\sqrt{10}}\\ \frac{3}{\sqrt{10}}\end{array}\right)
Any of those are eigenvectors corresponding to eigenvalue 4. Now, what are the eigenvectors corresponding to eigenvalue -1?
I thought that just by replacing the y in
with 3x would give me the eigenvector. I then multiplied it with the eigenvalue 4 and took the x out. So the eigenvector can also be
\left(\begin{array}{c}2 \\ 6\end{array}\right) \left(\begin{array}{c}3 \\ 9\end{array}\right) \left(\begin{array}{c}5 \\ 15\end{array}\right) ?
When \lambda = -1, I get
\left( \begin{array}{cc} 3 & 2 \\ 3 & 2 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = -\left( \begin{array}{c} x \\ y \end{array} \right)
and the equations 3x + 2y = -x and 3x +2y = -y. From these two equations I get y = x so the eigenvector is -\left(\begin{array}{c}1 \\ 1\end{array}\right) ?
Your work is easy enough to check, and you should do this. If \lambda is an eigenvalue with associated eigenvector x, then Ax better be equal to \lambdax. If not, then you have a mistake.
OMG I got a typo. a22 should be -3. Apologies.
\left( \begin{array}{cc} -2 & 2 \\ 3 & -3 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 4\left( \begin{array}{c} x \\ y \end{array} \right)
If \lambda is an eigenvalue with associated eigenvector x, then Ax better be equal to \lambda x. If not, then you have a mistake.
From what I understand, by that you mean from the equation
where the eigenvector is
I can replace the x with 1 and y with 3:
\left( \begin{array}{cc} -2 & 2 \\ 3 & -3 \end{array} \right)\left( \begin{array}{c} 1 \\ 3 \end{array} \right) = 4\left( \begin{array}{c} 1 \\ 3 \end{array} \right)
Solving the Ax part, I get
\left( \begin{array}{cc} -2 & 2 \\ 3 & -3 \end{array} \right)\left( \begin{array}{c} 1 \\ 3 \end{array} \right) = \left( \begin{array}{c} -2(1) + 2(3) \\ 3(1) + (-3)(3) \end{array} \right) = \left( \begin{array}{c} 4 \\ -6 \end{array} \right)
but it doesn't equal to
\lambda x = \left( \begin{array}{c} 4(1) \\ 4(3) \end{array} \right) = \left( \begin{array}{c} 4 \\ 12 \end{array} \right)
Does this mean I got it wrong?
No, you're looking at Ax = \lambda x where x is your eigenvector and lambda is your eigenvalue and A is still your original A = \left( \begin{array}{cc} 2 & 2 \\ 3 & 1 \end{array} \right). You plug in your eigenvector at this point and verify you get the vector back multiplied by its respective eigenvalue.
The reason you don't have simply 1 eigenvector is that you can start as Ax = \lambda x and say, let your new eigenvector be 3x where x is what you call "the eigenvector", that is A(3x) = \lambda (3x) which gives you 3Ax = 3\lambda x which is simply Ax = \lambda x still, thus any multiple of the eigenvector you found is another eigenvector.
Ahh.. so I don't actually need to multiply the eigenvector with the eigenvalue to see if they are equal?
Yes you still need to. Remember, the idea here is finding a vector that when acted upon by your matrix A, you return the vector multiplied by the eigenvalue. No matter what constant you multiply your eigenvector by, that is x -> cx where c is a constant, when you multiply from the left with A you still must return that eigenvalue multiplied by cx.
Oh wait!
\left( \begin{array}{cc} 2 & 2 \\ 3 & 1 \end{array} \right)\left(\begin{array}{c}1 \\ 3\end{array}\right) = 4\left(\begin{array}{c}1 \\ 3\end{array}\right)
\left(\begin{array}{c}8 \\ 6\end{array}\right) = \left(\begin{array}{c} 4 \\ 12 \end{array}\right)
But it doesn't matter because both are multiples of \left(\begin{array}{c}1 \\ 3\end{array}\right) ?
fuzzyorama said:
Oh wait!
No, they must be exact. You're still using the wrong eigenvectors, I thought you realized that earlier when you mentioned the typo you made. When you found your eigenvector for lambda = 4, you found 2 equations that were inconsistent -2x + 2y = 4x \mbox{~and~} 3x -3y = 4y . This should have immediately told you that something was wrong.
Basically, at this point: <br /> \left( \begin{array}{cc} -2 &amp; 2 \\ 3 &amp; -2 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 4\left( \begin{array}{c} x \\ y \end{array} \right) <br /> you should know that somethings wrong since the rows have to be linearly dependent (that is, rows are a multiple of each other) to solve for eigenvectors.
This is the wrong equation to use. The matrix on the right has to be A, and not the modified one with the subtracted eigenvalues.
If you want to use the modified matrix as you are, you need to set the right hand side equal to 0.
Basically you're making the mistake of this:
y=x Original equation
and then:
y-x=x WRONG
y-x=0 CORRECT
but in matrix form.
I make this mistake myself quite often.
Thanks for pointing that out:smile: Now I will redo everything.
A = \left( \begin{array}{cc} 2 &amp; 2 \\ 3 &amp; 1 \end{array} \right)
\left\vert \begin{array}{cc} 2 - \lambda &amp; 2 \\ 3 &amp; 1 - \lambda \end{array} \right\vert = 0
(2 - \lambda )(1 - \lambda) - (3)(2) = 0
2 - 2\lambda - \lambda + \lambda^2 - 6 = 0
\lambda^2 -3\lambda - 4 = 0
\therefore \lambda = -1, 4
When \lambda = -1,
\left( \begin{array}{cc} 2 - (-1) &amp; 2 \\ 3 &amp; 1 - (-1) \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 0
\left( \begin{array}{cc} 3 &amp; 2 \\ 3 &amp; 2 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 0
3x + 2y = 0
2y = -3x
\therefore y = -\frac{3}{2}x
Now I put this in my original matrix A (Ax = \lambda x)
\left( \begin{array}{cc} 2 &amp; 2 \\ 3 &amp; 1 \end{array} \right)\left( \begin{array}{c} x \\ -\frac{3}{2}x \end{array} \right) = -\left( \begin{array}{c} x \\ -\frac{3}{2}x \end{array} \right)
\therefore -x\left( \begin{array}{c} 1 \\ -\frac{3}{2} \end{array} \right)
Next, when \lambda = 4,
\left( \begin{array}{cc} 2 - 4 &amp; 2 \\ 3 &amp; 1 - 4 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 0
\left( \begin{array}{cc} -2 &amp; 2 \\ 3 &amp; -3 \end{array} \right)\left( \begin{array}{c} x \\ y \end{array} \right) = 0
-2x + 2y = 0
3x - 3y = 0
\therefore x = y
\left( \begin{array}{cc} 2 &amp; 2 \\ 3 &amp; 1 \end{array} \right)\left( \begin{array}{c} x \\ x \end{array} \right) = 4 \left( \begin{array}{c} x \\ x \end{array} \right)<br />
\therefore x\left( \begin{array}{c} 1 \\ 1 \end{array} \right)
Dayum this took quite a while heh.
At \therefore y = -\frac{3}{2}x, what this is telling you is that the solution to your system of equation is ANY matrix such that the y-entry is -3/2 of the x-entry. For example, you can try \left( {\begin{array}{*{20}c} 2 \\ { - 3} \\\end{array}}\right) for example. Any constant multiple of that eigenvector is an eigenvector as well! You can normalize it and use <br /> \left( {\begin{array}{*{20}c}<br /> {\frac{2}{{\sqrt {13} }}} \\<br /> {\frac{{ - 3}}{{\sqrt {13} }}} \\<br /> \end{array}} \right) for example! Plug it into your original equation and you'll see both work.
Also, having the x multiplying your eigenvector is kinda confusing as it look slike you're multiplying your eigenvector by another matrix x.
I got it right?
Understood! So it can also be
\left( {\begin{array}{*{20}c} 4 \\ { - 6} \\\end{array}}\right) ?
Yes, it can be any constant multiple. Simply plug it in and see what pops out to make sure you have an eigenvector.
\left( \begin{array}{cc} 2 &amp; 2 \\ 3 &amp; 1 \end{array} \right)\left( \begin{array}{c} 2 \\ -3 \end{array} \right) = -\left( \begin{array}{c} 2 \\ -3 \end{array} \right)
2(2) + 2(-3) = -2
3(2) + 1(-3) = 3
I GOT IT RIGHT! YOU GUYS ARE THE AWESOMEST! THANKS :!) :!) :!)
  • · Replies 33 ·
