Speed of Light Reflection: Einstein's Train & Mirrors
  • Context: High School
  • Thread starter Thread starter zasvitim
    Mirror Train
This discussion centers on the implications of Einstein's second postulate of special relativity regarding the speed of light as observed from different frames of reference, specifically within a moving train and from an external observer. It establishes that the speed of light remains constant at ##c## for both observers, regardless of the motion of the mirrors reflecting the light. The conversation also highlights the inadequacy of classical velocity addition, introducing the correct formula for relativistic velocity addition: ##(u+v)/(1+uv/c^2)##. Furthermore, it addresses misconceptions about time dilation and the behavior of light in relation to moving mirrors.
  • Understanding of Einstein's second postulate of special relativity
  • Familiarity with Lorentz transformations
  • Basic knowledge of classical mechanics and velocity addition
  • Concept of time dilation in relativistic physics
  • Study Taylor and Wheeler's "Spacetime Physics" for a comprehensive understanding of relativity
  • Learn about the implications of Lorentz transformations in different inertial frames
  • Explore experimental evidence supporting the constancy of the speed of light
  • Investigate the behavior of light in moving media and its effects on frequency and momentum
Students of physics, educators teaching special relativity, and anyone interested in the foundational principles of modern physics and their implications on our understanding of light and motion.
  • #31
zasvitim said:
And there is no difference if mirrors moves away or not? Did you ever play billiards? Do you imagine that ball that bonces back from another ball does not care if it is stationary or moves away with almost maximum speed?
When light reflects from a mirror that is moving relative to an observer, then its energy, frequency and magnitude of momentum (relative to the observer) do all change, but its speed does not.
As has been previously mentioned, when you switch from one observer to another, velocity changes according to formula$$
\frac {u + v} {1 + \frac{uv}{c^2} }
$$ and when you put ##v=c## you get the answer ##c## for all values of ##u## (and ##v=-c## gives ##-c##).
  • #32
Have you played billiards with photons or another massless particle?
  • Haha
  • Love
  • #33
I was tempted but knowing how difficult this subject is for me, I thought people in glass houses and all that!
  • Haha
  • #34
Already answered:
A.T. said:
The reflection at a moving mirror can change the frequency and thus momentum of the light, but not its speed in inertial frames of reference.
  • #35
zasvitim said:
So where is it?
If you're referring to the red lines drawn where there is no more jet, there's two reasons. For the lower right line, the jet simply stops being ionized and thus stops being visible, as it emits no more light once the matter is neutral.
The jet that would be where the top left line is located is not visible because of relativistic beaming, which redshifts the light and reduces the luminosity of the emitted light to such an extent that it is buried in the background noise and isn't visible.
If we were nearly side on the jets would look similar to these jets from NGC 383:
  • #36
Maybe this is way too primitive. But doesn't most of these variables affect the different end results how far the light travels and how much time it takes accordingly?
-PoV
-Angle
-Distance
This might be a 0.000000000001-ish difference, yet its a difference.
  • #37
-PoV
-Angle
-Distance
If you measure the distance the light travels over some time interval, it is ALWAYS c in a vacuum. The only things that change how long it takes to reach some point is the distance to that point and the path the light takes to reach it.
In the context of astrophysical jets, the light is traveling in very nearly a straight line to get to us, so the only other variable left is the actual distance between the jet and ourselves.
  • #38
No. The speed ##c## is invariant. It this the same in the mirror's rest frame and in each other frame.
There is a difference.
As others mentioned, billiard balls have a non-zero invariant mass
##m=\frac{E}{c^2}\sqrt{1-u^2/c^2}##.
Light has ##m=0## and therefore moves at ##u=c##.
  • #39
I'm not sure how this can be sensibly discussed. It's effectively saying you don't believe relativity and you guess the correct answer is something different. OK, so now what?
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 93 ·
  • · Replies 26 ·
  • · Replies 51 ·
  • · Replies 36 ·
