Elastic collision - finding ratio between m2 and m1, v2 and v1
In the discussion about elastic collisions, the problem involves two balls with one ball of known mass m and another of unknown mass M, both initially moving towards each other with speed Vo. After the collision, ball M comes to rest, while ball m has a new velocity V1'. The conservation of momentum and kinetic energy equations lead to two potential solutions for the ratios M/m and V1'/Vo, yielding results of x = 3 (M = 3m) and x = 0 (M = 0). However, the trivial solution where M = 0 is deemed unrealistic in this context, leaving the valid solution as M = 3m. The discussion emphasizes the need to eliminate the trivial solution to arrive at a single, meaningful answer.
an_mui
A ball of mass m and a ball of unknown mass M approach each other from opposite directions and have the same speed Vo (but oppositely directed velocities). The ball of M is reduced to rest by the impact, while the ball of mass m has a velocity V1'. What are the ratios
a) M / m
b) V1' / Vo
This is what I've done so far. I ended up with 2 answers, but we're only supposed to have one.
Conservation of momentum: mVo + M(-Vo) = mV1' + 0
- divide both sides by mVo, and let x = M / m, y = V1' / Vo
... equation (1'): 1 - x = y
Conservation of kinetic energy: 1/2mVo^2 + 1/2M(-Vo)^2 = 1/2mV1'^2
- divide both sides by 1/2mVo^2
... equation (2'): 1 + x = y^2
equations (1') + (2'): y^2 + y - 2 = 0
(y + 2)(y - 1) = 0
... y = -2 or 1
Case 1:
If y = -2, x = 3
Case 2:
If y = 1, x = 0
I don't know how we're supposed to determine which is the correct case. Please help!
a) M / m
b) V1' / Vo
(y + 2)(y - 1) = 0
... y = -2 or 1
Case 1:
If y = -2, x = 3
Case 2:
If y = 1, x = 0
You have:
1 + x = (1 - x)^2 = 1 - 2x + x^2
x^2 - 3x = 0
So: x = 3 = M/m so M = 3m
AM
thanks for your answer, but that doesn't solve the problem though... because from the above equations i had y = -2, x = 3 and y = 1, x = 0. From your answers x could also be 3 or 0. I need to eliminate one of the answers but i don't know how.
The two equations you must solve are:
Momentum conservation
mv_o - Mv_o = mv_1
Energy Conservation
\frac{1}{2}mv_o^2 + \frac{1}{2}Mv_o^2 = \frac{1}{2}mv_1^2
Express v1 in terms of m, M, and vo from the first equation and substitute it into the second equation. You should be able to solve that without a problem.
Edit: About what you claim about x being zero. This is a trivial solution that is usually present in all types of problems. You can conserve momentum and kinetic energy if you have nothing happening with nothing right? But why bother.
If x = 0, then M=0. That possibility is excluded by your fact situation.
AM
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 27 ·
