Elastic collision of two asteroids
The discussion revolves around solving a physics problem involving the elastic collision of two asteroids of equal mass. Asteroid A, initially traveling at 40.0 m/s, is deflected at a 30-degree angle after colliding with asteroid B, which moves at a 45-degree angle. The key equations for conservation of kinetic energy and momentum are highlighted, emphasizing the need to consider both x and y components of momentum. There is uncertainty about assuming asteroid B is initially at rest, as this affects the calculations. The concept of kinetic energy dissipation in elastic collisions is clarified, noting that while kinetic energy may change, it is not dissipated in the traditional sense.
Arejang
Two asteroids of equal mass in the asteroid belt between Mars and Jupiter collide with a glancing blow. Asteroid A, which was initially traveling at 40.0 m/s, is deflected 30.0\circ from its original direction, while asteroid B travels at 45.0 \circ to the original direction of A
Find the speed of asteroid A and asteroid B after the collision.
What fraction of the original kinetic energy of asteroid A dissipates during this collision?
Conservation of Kinetic energy
1/2m_{a}v_{a1x}^{2}+1/2m_{b}v_{b1x}^{2}=1/2m_{a}v_{a2x}^{2}+1/2m_{b}v_{b2x}^{2}
Conservation of momentum
m_{a}v_{a1x}+m_{b}v_{b1x}=m_{a}v_{a2x}+m_{b}v_{b2x}
I really want to assume that asteroid B is initially at rest, but since it's not stated; I'm not sure I should do so. But for this problem, I feel like it may be the only way to solve this problem so that's what I will assume, please correct me if I'm wrong. Anyway, it seems like you would have to solve for one of the final velocities through substitution. Since the masses of the two asteroids are the same, we can factor them out of both equations, leaving us with only the velocities to worry about.
So our Kinetic Energy Conservation formula looks like this:
1/2v_{a1x}^{2}+1/2v_{b1x}^{2}=1/2v_{a2x}^{2}+1/2_{b2x}^{2}
I then proceeded to solve for v_{a2x} and got
v_{a2x}=\sqrt{v_{b2x}^{2}-v_{a1x}^{2}}
This expression of v_{a2x} I subbed into the momentum conservation formula, getting:
v_{a1x}=v_{b2x}+\sqrt{v_{b2x}^{2}-v_{a1x}^{2}
It seems logical that I solve for the velocity of asteroid B, then plug that in the kinetics formula then solve for A, but I'm not certain how to integrate the angle of the collisions into each formula. In fact, I'm actually not sure if I even approached this problem correctly. But please let me know where I need to go with this.
Oh and to Doc. Al if you're reading this, it turned out my previous problem was correct and that the online problem had the wrong answer input as the correct one. Consequently, everyone got full credit for the problem.
Bump! Can anyone help me please?
I think you'd have to assume asteroid B is at rest initially for it to be possible since, in a nutshell, you'd absolutely have to know the total energy of the system initially, and that would be mighty hard to do without enough info
For my mental image I picture the asteroid A initially traveling down the positive x axis, and colliding with B at the origin, then A is traveling 30 degrees "north" of the x-axis and B is 45 degrees "south" of the x axis
So the initial momentum of the system is just the mass of A times its initial velocity, it's all in the +x direction
Afterwards, remember that the x-component of the momentum needs to be conserved, and the y components need to cancel.
The angles come into play because you use trig to find the x and y components of the velocity
The kinetic energy dissipated question is a pseudo-trick question. coughcoughelasticcolissiondefinitioncough
EDIT: Well I should be careful with that. In an elastic collision no energy is dissipated into other forms like heat or anything. The kinetic energy of asteroid A may, and I think will have to be, different than it was initially. But it wasn't "dissipated" >_>
The kinetic energy of the SYSTEM is the same though, so uh, interpret that how you will ^_^
LOL...hee hee...:smile:
So how would I be able to utilize a mass that's not given?
Well they're the same so there should be cancellation
In the x-direction:
The momentum before is going to be mass times velocity in the x direction(which with the way I drew it is just its speed) and the momentum after is going to be the mass times velocity in the x direction of A and B, those velocity components can be found using trig and those angles. All the masses cancel
Same thing in the y direction except the initial momentum is 0
