Elastic Collision Problem involving KE
In an elastic collision between a light and a heavy object, the distribution of kinetic energy (KE) depends on both mass and velocity. KE is conserved, meaning the total KE before and after the collision remains constant. The light object may have a high velocity, allowing it to carry significant KE, while the heavy object may have a low velocity, resulting in less KE despite its mass. The outcome varies based on their initial speeds; if both have equal speeds, the heavier object will have more KE, but if the lighter object is faster, it can possess more KE. Understanding these dynamics is crucial for analyzing elastic collisions effectively.
sj12390
In a collision a light object and a heavy object (elastic) which one has more KE? Does the answer depend on the initial speeds?
Conservation of KE
Since this is an elastic collision, KE is conserved. However, I was thinking that it would be impossible to tell which carries away with more of the KE because KE is determined based on mass AND velocity. While the light object might have a tiny mass, it could be traveling extremely fast and likewise, the heavy object could have a huge mass, but it could also be traveling extremely slowly. I'm just not sure if this is the correct logic, though. Any help would be appreciated!
You could answer this question like, "If the two intial speeds are equal then..." and then answer the second part by saying, "If the initial speed of the lighter object is greater than that of the heavy object then..." and vce versa.
