Elastic or inelastic collision?
The discussion centers on the definitions and characteristics of elastic and inelastic collisions. An elastic collision is defined as one in which kinetic energy is conserved, while inelastic collisions do not conserve kinetic energy. The scenario presented, where two objects collide and stick together, leads to the conclusion that if kinetic energy is conserved, the collision is elastic. The conversation emphasizes the importance of understanding these definitions to avoid contradictions in collision scenarios.
  • Understanding of kinetic energy conservation
  • Familiarity with the definitions of elastic and inelastic collisions
  • Knowledge of conservation of momentum principles
  • Basic physics concepts related to collisions
  • Study the principles of conservation of momentum in collisions
  • Learn about the mathematical equations governing elastic and inelastic collisions
  • Explore real-world examples of elastic and inelastic collisions
  • Investigate the effects of external forces on collision outcomes
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of collisions in classical mechanics.
Mohamad
If the initial kinetic energy is equal to the final kinetic energy where two objects that collide stick together, this collision is elastic or inelastic?
If my grandmother has wheels she still isn't a school bus.
What collision scenario do you have in mind ?
Mohamad said:
Summary: elastic or inelastic collision?
Clearly you do not understand the basic definitions of elastic and inelastic collision. You could at least look those up before proceeding.
An "elastic collision" is, by definition, one in which kinetic energy is conserved. Since, in an inelastic collision, we don't have the "conservation of kinetic energy" equation, we need another condition to solve for the speeds after the collision. Often that is given by requiring that the two objects stick together, but that is not necessary. We can have an inelastic collision in which the two objects do not stick together and we can have an elastic collision in which the two objects do stick together. Here, we are given that kinetic energy is conserved so this has to be an elastic collision.
I thought we weren't supposed to spoon-feed the answers. :frown:
I had already asked him to look up the defintions so that he could figure that out for himself.
Using conservation of momentum (which holds regardless if the collision is elastic or inelastic,unless there is net external force which is comparable in magnitude with the magnitude of the big forces that arise due to collision) we can prove that IF the two bodies stick together then the kinetic energy isn't conserved.
So your scenario is contradictory. Either the bodies don't stick together, or the kinetic energy isn't conserved, you can't have both. OR there are external forces in play.
Or the objects were spinning just right so that they could latch onto one another without dissipating any energy. They can then spin about one another, each retaining its original (and rotational) kinetic energy in the combined center-of-momentum frame.
The way I interpreted "stick together" is that they have exactly the same velocity after the collision. In the scenario you describe they don't have the same velocity after the collision (spinning about one another means they have opposite and equal velocities (in the best scenario) if I understand it properly)
Yes, the typical assumption with "stick together" is a head-on collision, ignoring the possibility of a resulting rotation. But a literal reading of the problem statement in #1 above allows the possibility.
  • · Replies 25 ·
