Electric Field above a Quarter Disk
The discussion focuses on calculating the electric field at a distance z above the xy-plane due to a constant surface charge σ on a quarter disk defined between radii a and b. Key equations include Coulomb's law, E = kq/r², and the differential area element dA = (π/2) * r' * dr'. Participants emphasize the importance of vector notation and integrating in cylindrical coordinates to account for the lack of symmetry in the problem.
  • Understanding of electrostatics and electric fields
  • Familiarity with Coulomb's law and vector calculus
  • Knowledge of cylindrical coordinates and integration techniques
  • Basic concepts of surface charge density and its implications
  • Study the application of cylindrical coordinates in electrostatics
  • Learn about vector calculus in the context of electric fields
  • Explore the derivation of electric fields from surface charge distributions
  • Investigate the implications of symmetry in electrostatic problems
Students and professionals in physics, particularly those focusing on electrostatics, as well as educators looking for detailed examples of electric field calculations involving non-symmetric charge distributions.
Squire1514
  • 1. Problem Statement.
Find the Electrostatic Field at a distance z above the xy-plane and along the z-axis due to a constant surface charge σ confined to the region a < √(x2+y2) < b, 0 < α < pi/2.
In other words, find the Electric Field a distance z above a quarter disk occupying the region between the positive x and y axes from r = a to r = b.
  • 2. Known Equations
E = kq/r2
dq = σdA
dA = pi/2 * r' *dr'
r = √(r'2+z2)
  • 3. Attempt
The lack of symmetry is what loses me in this question. I know I need to set up tiny quarter rings and then integrate from A to B but I don't know what to do about the vector notation.
You can break it into x, y, z coordinates. r^2 = (x^2 + y^2 + z^2).
Write it as a double integral over dx and dy.
Note to the Homework Helpers: This was originally posted in the Classical Physics forum. I moved it here instead of deleting it because the OP showed some thought and posted in a format that sort of resembles the homework forums template. Carry on!
Squire1514 said:
dA = pi/2 * r' *dr'
Firstly, here I think you must write \displaystyle{dA=rdrd\varphi } (\displaystyle{\varphi } is the azimuth). Note that if you have two charges at the same distance from the origin but in different angles they don't create the same field at the point along the z-axis. The two fields have the same magnitude but different direction! So you can not neglect the angle at the integration as you integrate vector to find the field.
Squire1514 said:
  • 3. Attempt
You can solve it in such a way, but you have to find the field of the ring at first. So I think it's easier to use double integral in cylindrical coordinates (that's from where the \displaystyle{dA } I write above comes from). It's almost the same method with yours but you can find immediately the total field of the disk.
To take into account that \displaystyle{\vec{E}} is a vector it may help you to write Coulomb's law like that:
\displaystyle{d\vec{E}=\frac{dq}{4\pi \varepsilon _0}\frac{\vec{z}-\vec{r}}{\left|\vec{z}-\vec{r} \right|^3}=\frac{dq}{4\pi \varepsilon _0}\frac{\vec{z}-\vec{r}}{(r^2+z^2)^{3/2}}}
where \displaystyle{\vec{z}} is the point where you want to find the field position vector and \displaystyle{\vec{r}} is \displaystyle{dq} position vector.
You can analyze these vectors in the Cartesian unit vectors and then use a double integral in cylindrical. Note that it's difficult to integrate with cylindrical unit vectors because they are not constant!
21K
