Electric field between parallel plates
4 replies · 2K views
lys04
The electric field outside a conducting plate of charge is given by sigma/epsilon right? Then why not for a capacitor, since that is 2 conducting plates, is the electric field 2sigma/epsilon using superposition principle?
E=sigma/epsilon
Here’s a cross -section through (due to space limitations, part of) an infinite conducting plate with a (say) positive charge:
___________________________
Here are some questions to consider:
- are both surfaces charged?
- if only one (of the two) surfaces is charged, what determines which one?
- in a static situation, every ‘field line’ starts on a positive charge and ends on a negative charge; where are the negative charges here?
Reply
lys04 said:
Homework Statement: The electric field outside a conducting plate of charge is given by sigma/epsilon right? Then why not for a capacitor, since that is 2 conducting plates, is the electric field 2sigma/epsilon using superposition principle?
Relevant Equations: E=sigma/epsilon
Generally, the two plates of a capacitor are oppositely charged. Right?
So, if one plate has a surface charge density, ##\sigma##, then the other plate has surface charge density, ##-
\sigma##,
Now use superposition to determine the electric field outside the plates as well as between the plates.
Reply
