Electric Field/Electric Potential (Gradient Notation)
4 replies · 14K views
PFStudent
Hey,
I have a question about Electric Field/Electric Potential gradient notation.
Since,
[tex] {\vec{E}} = {-}{\nabla}{V(r)}[/tex]
Which reduces to,
[tex] \vec{E} = {-}{\nabla}{V(x, y, z)}[/tex]
When expanded is,
[tex] \vec{E} = {-}{\left[{\frac{\partial[V]}{\partial{x}}}{\hat{i}} + {\frac{\partial[V]}{\partial{y}}}{\hat{j}} + {\frac{\partial[V]}{\partial{z}}}{\hat{k}}\right]}[/tex]
So using partial derivative notation can I write,
[tex] {\vec{E}} = {-}{\vec{V}'_{xyz}}[/tex]
So, is the above correct notation?
The reason I am hesitant is, because formally the gradient is defined as a vector operator that takes a scalar field (such as the electric potential) and changes it to a vector field (such as the electric field) through: partial differentiation with the addition of unit vectors ([tex]\hat{i}, \hat{j}, \hat{k}[/tex]).
However, writing it as below sort of implies the potential is a vector (which it isn't), but gives the impression that it is because of how the gradient is defined.
So, is the above notation correct?
-PFStudent
-PFStudent
I wouldn't use it. I would just leave it as:
Or
[tex] {\vec{E}} = {-}{\nabla}{V}[/tex]
No, it is not correct. That is, there is no notation I know of that looks like that that is defined as the gradient of a scalar field.
As the above poster says, there is nothing wrong with [itex]\vec{E}=-\nabla V[/itex]
Hey,
Yea, thanks for the input, I can see why that notation,
[tex] {\vec{E}} = {-}{\vec{V}'{xyz}}[/tex]
is wrong. Since, we are adding the components of a vector that is not the same as taking the partial derivative of a function with respect to each of the variables.
Since, all the gradient is doing is the following,
[tex] \vec{E} = {-}{\nabla}{V(x, y, z)} = {-}{\left[{\frac{\partial}{\partial{x}}{\left[V\right]}} + {\frac{\partial}{\partial{y}}}{\left[V\right]}} + {\frac{\partial}{\partial{z}}}{\left[V\right]}}\right]}{\hat{r}}[/tex]
Thanks,
-PFStudent
Hey,
I've been thinking about this and I have a follow up question.
Since,
[tex] \vec{E} = {-}{\nabla}{V(r)} = {-}{\left[{\frac{\partial}{\partial{x}}{\left[V\right]}} + {\frac{\partial}{\partial{y}}}{\left[V\right]}} + {\frac{\partial}{\partial{z}}}{\left[V\right]}}\right]}{\hat{r}}[/tex]
and also,
[tex] E = {-}{\frac{\partial}{\partial{r}}}{\left[{V(r)}\right]}[/tex]
So then,
[tex] \vec{E} = {-}{\nabla}{V(r)} = {-}{\frac{\partial}{\partial{r}}}{\left[{V(r)}\right]}{\hat{r}}[/tex]
Now can I rewrite the above as below?
[tex] \vec{E} = {-}{\frac{\partial}{\partial{(x, y, z)}}}{\left[{V(x, y, z)}\right]}{\hat{r}}[/tex]
Which for [tex]{E}[/tex] can also be written as,
[tex] {E} = {-}{\frac{\partial}{\partial{(x, y, z)}}}{\left[{V(x, y, z)}\right]}[/tex]
So, is the notation for the above two equations correct?
Thanks,
-PFStudent
