How Does Gauss' Law Account for the Negative Plate in a Capacitor?
This discussion clarifies the application of Gauss' Law in analyzing electric fields in capacitors, specifically addressing the role of the negative plate. When calculating the electric field using Gauss' Law, the field due to the positive plate is E = σ/(2ε₀). However, the total electric field between the plates is E = σ/ε₀, as the fields from both plates add together. The presence of the negative plate is crucial as it amplifies the electric field between the plates while canceling it outside, confirming that both plates must be considered for accurate calculations.
  • Understanding of Gauss' Law
  • Familiarity with electric fields and capacitance
  • Knowledge of parallel plate capacitors
  • Basic concepts of charge density (σ) and permittivity (ε₀)
  • Study the derivation of electric fields using Gauss' Law in capacitors
  • Explore the concept of charge distribution on parallel plates
  • Learn about the effects of edge effects in capacitor fields
  • Investigate the relationship between electric field strength and capacitance
Students of electromagnetism, electrical engineers, and anyone seeking to deepen their understanding of capacitor behavior and electric field calculations.
kash25
Hi,
I have a problem with electric fields in capacitors. Using Gauss' Law, we always choose the Gaussian surface that encloses the positive plate in the capacitor. When we go through field calculations, we get an equation for the electric field and we use that to find voltage, capacitance, and everything else. What I don't understand is how enclosing ONLY the positive plate takes into account the fact that the negative plate is present and that it amplifies the field between the two. In other words, how would our calculations or conclusions be any different if the negative plate were not even present?
Thank you very much for the help
Hi kash25,
I don't think that's correct. For example, for parallel plates we might use Gauss's law to find the electric field of just the positive plate (giving a result of E = \sigma/(2\epsilon_0) everywhere), but then we would double that to find the electric field of the capacitor between the plates (E=\sigma/\epsilon_0) and set the field to be zero outside the plates.
(Between the plates, the fields are in the same direction and so add; outside the plates they are in opposite directions and therefore cancel; also I'm making the usual approximation that the nonuniform field at the ends of the plate can be neglected, etc.)
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 18 ·
