What Determines the Electric Field Inside a Spherical Cavity?
The electric field inside a spherical cavity containing a point charge is not zero, contrary to initial assumptions. The induced charges on the cavity surface do not cancel the electric field created by the point charge at the center. According to Gauss' Law, the electric field inside the cavity is determined by the point charge and remains present regardless of the cavity's shape or position within the conducting sphere. This conclusion emphasizes the importance of understanding the behavior of electric fields in electrostatics.
  • Understanding of Gauss' Law
  • Familiarity with electric fields and point charges
  • Knowledge of spherical symmetry in electrostatics
  • Basic concepts of induced charge in conductors
  • Explore applications of Gauss' Law in non-symmetric charge distributions
  • Study the electric field outside a conducting sphere with a cavity
  • Investigate the effects of multiple point charges within a cavity
  • Learn about the behavior of electric fields in dielectric materials
Students and professionals in physics, particularly those studying electrostatics, as well as educators looking for clear explanations of electric field behavior in conductive materials.
rockbreaker
Hi, I am dealing with a problem in Electrostatics.
There is a sphere with a spherical cavity in it. The sphere itself does not have net charge, but inside the cavity, there is a point charge at the center of the cavity. What's the electric field inside the cavity?
Gauss' Law, E=Q/(4*Pi*epsilon0*r^2)
I assume the field is 0 because the induced charges on the cavity surface cancels the field of the point charge in it. Is this assumption correct?
No, the assumption isn't correct. The induced charge in fact support that there is an electric field inside the cavity. try to work it out
That assumption isn't correct for the electric field inside the cavity (inside of the surface containing the induced charges).
If it helps to understand why, remember what the electric field is inside of a uniformly charged, spherically symmetric shell without any other charges in it. Then consider what the electric field is if there is an additional charge at the center, all else being the same.
Now use Gauss' Law to apply that to this problem with the cavity. You shouldn't even have to assume that the cavity is symmetric -- it can be of any shape. Also, the cavity, and the charge inside of it, doesn't need to even be centered in the conducting sphere -- it can be anywhere within the sphere.
After you answer this step, it's the next steps that end up being rather fascinating and insightful. You will be invariably asked next to find the electric field within the conducting sphere, but outside the cavity, and then to find the electric field outside of the entire conducting sphere.
Hint: At first this might seem like a very mathematically intense exercise, but it is not. If you use Gauss' Law it turns out to be a surprisingly simple problem (well, comparatively simple for an electrostatics problem anyway). Most of this exercise is thinking about Gauss' Law qualitatively.
You're right, I actually confused this problem with a dielectrical sphere. It is pretty obvious using Gauss' Law that there has to be an electric field inside the cavity when there is a charge inside it (which ends at the surface of the cavity to guarantee that the conductor is field-free). Thank you very much!
