Electric field of a hollow sphere WITH surface thickness.
The problem involves finding the electric field of a hollow spherical shell with a charge density that varies with radius, specifically in the regions inside and outside the shell. The charge density is given as a function of radius, leading to different considerations for the electric field in the specified regions.
  • Participants discuss the implications of the charge density being a function of radius and question the assumption that charge is only on the outer surface. There are attempts to apply Gauss's Law and considerations of how to calculate the enclosed charge.
There is ongoing exploration of the mathematical approach to find the electric field, with some participants clarifying misunderstandings about charge density and integration. Multiple interpretations of the problem are being discussed, particularly regarding the assumptions about charge distribution and the application of Gauss's Law.
Participants note that the problem does not specify whether the hollow sphere is a conductor or an insulator, which affects the assumptions about charge distribution. There is also mention of the need to integrate due to the non-uniform charge density.
Domfunkle
A hollow spherical shell carries charge density [tex]\rho[/tex] = [tex]\frac{k}{r^{2}}[/tex]
in the region a [tex]\leq[/tex] r [tex]\leq[/tex] b. Find the electric field in the three regions:
i. r < a
ii. a < r < b
iii. r > b
Surface Area of a sphere
Coulombs Law
Gauss's Law
i. This is easy, centre of a hollow charged sphere has E = 0
ii. ?
iii. Just used the sphere as a point charge and using the surface area of the sphere's outer radius, multiplied by the charge density to get the charge, and then just used Coulomb's Law to get E.
My problem is with part ii. The Electric Field within the thickness of the sphere. The question never specified that it was an insulator or a conductor, so I'm just going to assume that the majority of the charge lies on the outer radius surface, and that the inner radius surface should have little-to-no charge to account for the 0 E in the hollow centre, and the Field increases as the radius increases in the thickness: E [tex]\propto[/tex] r
Would i be right in this assumption? How might I describe this mathematically?
Your assumption is incorrect. The charge distribution is given as a function of r, so there is charge everywhere inside the shell. Consider using Gauss' Law. Your Gaussian surface should be a concentric sphere with radius r, a < r < b. Find the charge enclosed by this surface, find the flux through the surface and put it together.
Cheers for that kuruman, I thought my assumption might have been wrong, but I had a few different conflicting ideas on this.
So for example, if i was to use the differential form of Gauss' law: [tex]\nabla[/tex].E = [tex]\frac{\rho}{\epsilon}[/tex] , how might I infer the Electric Field itself from this divergence? 2nd Year Calculus coming back to haunt me..
I'll have a go now, using some "reverse-calculus" to get E by itself, but any more advice on this would be really appreciated.
Actually.. I think i have it now:
Using the Flux equations: [tex]\Phi[/tex] = E.A = E.4.pi.r^2 = Q/eps0
and then using Q = rho x Area of sphere, sub into flux and solve for E.
correct? incorrect?
EDIT: Actually.. this is how i worked out the Electric field for r > b.. damn.. back where I started
correct? incorrect?
Doesn't charge density mean the charge per unit volume, and not the charge per unit area? Use integration to find Q, then use Gauss' law as you've already done.
You're absolutely right! I'm getting myself confused here.. Instead of integrating the for the volume, could i perhaps use the shortcut method of V(sphere) = 4/3.pi.r^3 and just deduct the volume of the inner sphere from the larger sphere? would certainly simplify my calculations.
You can do that only if the density is uniform (equal charge in equal volume). Here the density depends on the radius. You have to integrate.
Kuruman is right..the distribution is not uniform, it depends from r...look at the thread i posted few days before by the title ''Gauss Law'' by Engels and u will find the solution. I had almost the same problem as you and i solved it
Ok, not sure if I'm doing it correctly here, but here's what I've done:
using Gauss' law:
[tex]\int_V\frac{\rho}{\epsilon_0} d\tau = \frac{Q}{\epsilon_0}[/tex],
so i then do:
[tex]\frac{Q}{\epsilon_0} = \int^{\pi}_{0}\int^{2\pi}_{0}\int^{r}_{a} \frac{k}{\epsilon_0 r^{2}} dr d\phi d\theta[/tex]
as it's a sphere with radial limits a through r.. correct?
Then I use coulomb's law to calculate E once I know Q.. correct?
PS. my equation typing skills are improving =]
using Gauss' law:
That's not Gauss' Law. The equation [itex]Q=\int_{\mathcal{V}} \rho d\tau[/itex] comes straight from the definition of charge density.
so i then do:
Not quite, the volume element in spherical coordinates is [itex]d\tau=r^2\sin\theta dr d\theta d\phi[/itex]
No, you use Gauss' Law.
argh!~ This is annoying the heck out of me!
Right, so re-evaluated:
[tex]\frac{Q}{\epsilon_0} = \int_V \frac{k}{\epsilon_0} sin(\theta) dr d\theta d\phi[/tex]
This is calculated down to a nice easy equation [tex]Q = 4k \pi (r-a)[/tex] giving charge enclosed between the shells radius r and a.. correct? This seems a little simple, but ahh well let's see where this goes.
So now I have the charge [tex]Q[/tex], now what do I do? I can't for the life of me figure this out. It should be so simple, there's some missing piece of the puzzle here..
I know i have to use the surface integral part of Gauss' law, but I can't find any worked examples on how to get E outta that damned integral.
anyone care for a brief tutorial?
Yes, it is simple. Luckily, it's also correct:smile:
Well, if you can find a Gaussian surface [itex]\mathcal{S}[/itex] where E will be constant over the surface and point normal to the surface, then you can say
[tex]\int_{\mathcal{S}} \textbf{E}\cdot d\textbf{a}=||\textbf{E}||\int_{\mathcal{S}} ||d\textbf{a}||=EA[/tex]
Right?
wait wait wait wait wait! I think I have it!
Was flipping through Griffiths and spotted a nice little trick for symmetry where E points radially outwards with the same magnitude at all points with the same radius:
[tex]\int_S E.da = \int_S |E|da = E4 \pi r^{2} = \frac{Q}{\epsilon_0}[/tex]
Sub my Q into that and solve for E.. does this sound right at all?
EDIT: argh! gabbagabbahey you beat me to it!
Right, you've already calculated the charge enclosed by a spherical surface of radius a<r<b. So as long as you can argue that E will point radially outward with the same magnitude at all points with the same radius, then yes, that's all you need to do.
WONDERFUL! Thank you so much for the help!
..and thanks to all who've assisted me with this irritating problem.
I've now concluded that [tex]E = \frac{k(r-a)}{\epsilon_0 r^{2}}[/tex] for the region enclosing a < r < b.
Looks good to me!:approve:
I are champion =]
