Electric Field Strength from point charges
The discussion focuses on calculating the electric field strength at point P due to charges positioned at the corners of a square. Participants clarify that the correct distance from charge nQ to point P is 2L², which must be squared in the electric field formula E(r) = kQ/r². The initial acceleration of a particle with charge q at point P is derived from this electric field. The superposition principle is emphasized, indicating that the total electric field is the vector sum of the fields from individual charges.
  • Coulomb's Law and its application in electric field calculations
  • Understanding of vector components in physics
  • Knowledge of the superposition principle in electrostatics
  • Familiarity with basic calculus for evaluating limits and derivatives
  • Study the derivation of electric fields from point charges using Coulomb's Law
  • Learn about vector addition and its application in electric field calculations
  • Explore the concept of electric field lines and their representation
  • Investigate the effects of multiple charges on electric field strength and direction
Students of physics, educators teaching electrostatics, and anyone interested in understanding electric fields and forces from point charges.
pingpong240
Question
Charges at three corners of a square are shown in Figure P26.34, in which n = 9. To answer the following questions, use the letters k, Q, q, L, and m.
IMAGE IS LOCATED HERE: http://www.webassign.net/knight/p26-34.gif
a) Write the electric field at point P in component form.
b)A particle with positive charge q and mass m is placed at point P and released. What is the initial magnitude of its acceleration?
Attempt at a Solution
Well, I was a little upset about this problem because I wonder if I'm getting the typing syntax correct. Anyways, here's what I came up with for an answer for the x coordinate of a(which is wrong):
-k(Q/(L^2))+kcos(45)((9Q)/(2L^2)^(1/2))
k is of course Coulomb's constant and Q is the charge, with L as the distance
Any ideas on what I am doing wrong here?
The electric field obeys superposition. This means that, to find the field from multiple charges, you just add up the field from each individual charge.
It looks like you're on the right track, but the *square* of the distance from nQ to P is 2L², not the square root of that.
yeah that's what i have i think, i double checked the format and what i have is equivalent to (L^2+L^2)^(1/2) or 2(L)^(1/2)
that's what you are talking about right?
i know the other charge doesn't get involved in the x coordinate...so what might i be doing wrong?
You calculated kcos(45)((9Q)/(2L^2)^(1/2)) as the contribution to E from nQ.
The number in the denominator, (2L²)^(1/2), is the distance from nQ to P. But your formula for the field magnitude, E(r) = kq/r², puts the square of the distance in the denominator. You are using the distance itself, not the square of the distance.
ah i see now. thank you very much i got it.
