Electric Field Zero: Where is the Point in Space?
The discussion revolves around finding the point in space where the electric field is zero due to two point charges, Q1 and Q2, with given magnitudes. The participants explore the setup of the problem, focusing on the distances from the charges and the resulting electric field equations.
  • Participants discuss the placement of a test charge and the conditions under which the electric fields from the two charges might cancel. There are attempts to derive equations based on the distances from the charges and the magnitudes of the charges involved. Some participants question the assumptions made regarding the regions where the electric field could be zero.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided calculations and results, while others express confusion regarding the correct approach and the implications of their findings. There is no explicit consensus on the final answer, but guidance has been offered regarding the setup of equations and the significance of the distances involved.
Participants note the complexity of the problem, particularly in terms of how the distances are defined relative to the charges. There is mention of the need to express answers in terms of L, which adds to the confusion for some. The discussion reflects a mix of correct and incorrect reasoning, with participants questioning the validity of their solutions and the assumptions made throughout the problem-solving process.
exitwound
E=kQ/d^2
If we choose a point P along the X-axis, with a distance X from the origin, we get this:
E_{P1}=\frac{kQ_1}{d^2}
E_{P2}=\frac{kQ_2}{d^2}
Assuming that Q=1 for simplicity:
E_{P1}=\frac{k(-7)}{(L+x)^2}
and
E_{P2}=\frac{k(3)}{x^2}
Basically, I've chosen P to be to the right of Q2, giving the distance between Q1 and P to be L+x and the distance between Q2 and P to be x.
If we want to find the point in space where the sums of the Electric fields is zero, we add up the field from Q1 and the field from Q2 and set equal to zero.
E_{P1}=\frac{k(-7)}{(L+x)^2} + \frac{k(3)}{x^2} = 0
E_{P1}=\frac{k(-7)}{(L+x)^2} = - \frac{k(3)}{x^2}
I end up with, after assuming L=1, cross-multiplying:
-7x^2 = (-3)(1+x)^2
But when I solve this, there is no real answer.
You chose the correct region to look for a net 0 field, (to the right of the 3.00q charge). However, when I solved this equation, I got x==6L.
0==-7k/(L+x)^2+3k/x^2
7/(L+x)^2==3/x^2
7==3(L+x)^2/x^2
7x^2==3(L+x)^2
7/3==(L+x)^2/x^2
7/3==(L^2+2xL+x^2)/x^2
Let L==1
7/3-2==2/x
0.3333333x==2
x==6
Since we let L==1, x==6*L==6
-7x^2 = (-3)(1+x)^2
Try again. You should get two real answers, only one of which is meaningful for this problem.
The only two regions is could possibly be zero are the outer two. The inner region would push a positive test charge to the left at all points. But on the outer two, there are possibly points where it could stabilize. How can I possible determine just by looking which one to try?
1.) To the right of the right particle.
If a positive test particle was placed here, it would be repelled by the 3Q charge and attracted by the -7Q charge. But the 3Q charge is much closer.
2.) To the left of the left particle.
If a positive test particle was placed here, it would be repelled by the 3Q charge and attracted by the -7Q charge. But the -7Q charge is much closer.
So just by looking, how can I tell which to choose?
7/(L+x)^2==3/x^2
7==3(L+x)^2/x^2
7x^2==3(L+x)^2
7/3==(L+x)^2/x^2
Let L==1
7/3-2==2/x <--------//Followed all the way up to here.
0.3333333x==2
x==6
At the marked point, I have identical work on my paper. How did you get to the next line?
The only way the field contributions can cancel is if you're closer to the smaller charge.
7/3==2.3333333333333333
2.3333333333333333333-2==0.3333333333333333333
I then brought the x term onto the left side of the equation, 0.333x==2, and divided by 0.333. x==6
Let L==1
7/3-2==2/x
No, letting L = 1 gives you:
7/3 = (1 + 2x + x^2)/x^2
(You still have to solve the quadratic.)
Okay, well...
This time I got it down to: 4x^2-6x-3=0
X turns out to be: -.395 and 1.90.
is 1.9 the correct answer? I don't want to lose any more points on this stupid assignment.
Also, why would I disregard the negative one? I know theoretically why i can't have a particle between the two and have a 0 E-field, but is this the reason why I'm disregarding the negative distance?
Yes, since you assumed L = 1, x=-.395 will be between the two charges.
1.90 is a wrong submission. Apparently, that is not the answer.
You ought to count from the origin...
I don't understand how to relate x to L in this problem.
What are the coordinates of q1 and q2? Therefore what is the coordinate of the point with zero E field?
As should be clear by now, the field can be zero only on the right of q2. Suppose it is zero at a distance s from it. Then, at that point the magnitude of the fields due to the two charge must be same. As such we get (after canceling \dfrac{1}{4\pi\epsilon_0} on both side):
\dfrac{|q_1|}{(L+s)^2}=\dfrac{|q_2|}{s^2}
That, is
\dfrac{|q_1|}{|q_2|}=\left(\dfrac{L+s}{s}\right)^2
so that
\dfrac{L+s}{s}=\pm\sqrt{\dfrac{|q_1|}{|q_2|}}
I can readily do away with the negative sign (all the quantities on the left are positive, since I called s as distance). So we get
\dfrac{L}{s}+1=\sqrt{\dfrac{|q_1|}{|q_2|}}
Finally, I get
s=\dfrac{L}{\sqrt{\frac{|q_1|}{|q_2|}}-1}
Plugging in numbers,
s=\dfrac{L}{\sqrt{7/3}-1}=1.90\,L
(taking the significant figures into account)
I'm lost at what I should enter into the submission box. 1.90 is NOT right, as it yelled at me and threw a pie at my face when I tried. Is the problem asking for a submission of 2.90? (If L=1, s=1.9, L+s=2.90)
Yes, it should be wanting 2.90.
Yes the answer for the problem would be 2.90. In my last post I found the distance from q2 of the point where the field is zero. The problem asks for the coordinates, i.e. the distance from the origin which is where q1 sits. So the answer should be L+s = 2.90 L
So u fill in 2.90.
2.90 is the correct answer.
These problems given on this online homework section are TERRIBLY overcomplicated. Why on Earth is it asking for an answer in multiples of L? I've never seen a question so convoluted in a math book. Why doesn't it just ask straight up "At what point on the x-axis..."??
They're really pretty much the same thing isn't it? If L is unknown you will have to give your answer in terms of L anyway.
Yes. Don't forget that when you set up your equation for x, x was the distance to the right of q2. To get the distance from the origin (where q1 is) you have to add L.
Indeed. But asking, "As a multiple of L...", is extremely confusing.
