Electric Fields inside Conductors & Gauss' Law
The discussion revolves around the behavior of electric fields inside conductors and the application of Gauss's Law in electrostatics. Participants explore the implications of these concepts in the context of a metal conductor sphere, addressing both theoretical and conceptual questions.
  • Some participants question why the electric field inside a metal conductor sphere is considered to be zero, suggesting that if an electric field were present, it would cause charges to move.
  • One participant notes that charges can move within a conductor and that the presence of an electric field would lead to electron movement, which would redistribute charges until the field inside is neutralized.
  • Another participant emphasizes that Gauss's Law applies to the flux through a closed surface, indicating that only enclosed charges contribute to the electric field calculation, while external charges do not affect the net flux through that surface.
  • Some participants express uncertainty about the conditions under which the electric field inside a conductor is zero, with one noting that this is only true in the electrostatic limit where the current density is zero.
  • There is a suggestion that the arrangement of electrons in response to an external electric field could potentially lead to a situation where the electric field inside is not zero, particularly in dynamic scenarios.
Participants express differing views on the conditions under which the electric field inside a conductor is zero, with some asserting it is always zero in electrostatic conditions, while others argue it may not hold true in all situations. The application of Gauss's Law also generates discussion regarding the contributions of enclosed versus external charges.
Participants highlight the importance of the electrostatic limit and the role of charge movement in determining the electric field inside conductors. There is also a focus on the implications of Gauss's Law in relation to closed surfaces and the nature of electric field contributions.
pandabear27
I am just starting to learn AP Physics C E&M, and I have some questions.
1. If I have a metal conductor sphere (neutral or charged), why is it that the electric field inside is always equal to 0?
2. Also, a question about Gauss's Law.
$$E \cdot A = \frac{Q_{enc}}{\varepsilon_0}$$
Since ##Q_{enc}## only accounts for the charges INSIDE of the Gaussian surface, when we solve for E, then does that only account for the electric field that is created by the enclosed charges, or also charges that could be outside of the Gaussian surface?
I would really appreciate any help. Thank you!!
Hello.
2. all charges both inside and outside the surface contribute to ##\mathbf{E}##.
$$\int_S \mathbf{E}\cdot d\mathbf{S}$$ is proportional to enclosed charges.
Got it, thank you!!
In a conductor, charges can move. What will happen to them if there is an E field inside the conductor?
Gauss' Law doesn't say that - it says $$\oint \vec E\cdot d\vec A=\frac{Q_{\mathrm{enc}}}{\varepsilon_0}$$The integral is important because Gauss is making a statement about the flux through a closed surface, not just some random non-closed surface.
Notice that a field line from a charge inside the surface will cross the surface once, and every field line from the charge will have the same sign for ##\vec E\cdot d\vec A## where it crosses. Thus the charge's contribution to the integral must be non-zero.
However, a field line originating outside the surface will cross twice, once inward and once outward, meaning it will make two opposite-signed contributions to the integral. They don't necessarily cancel exactly, but once you do the integral all these contributions do net to zero. So it's only charges inside the surface that matter for calculating the total flux.
1. I think if there's an E field inside the conductor, then the electrons would feel a force and start moving. Since electrons repel each other, they will go as far as possible, which is along the surface. How can this prove the ##E_{field} = 0##?
2. I see, that makes a lot of sense. Thank you so much!!!
pandabear27 said:
1. I think if there's an E field inside the conductor, then the electrons would feel a force and start moving. Since electrons repel each other, they will go as far as possible, which is along the surface. How can this prove the Efield=0?
It is not generally true that the E field in a conductor is 0. It is only true in the electrostatic limit where the current density is zero.
If they move when there's an E field, when will they stop moving? Might the changed arrangement of the electrons be able to provide that circumstance when added to your external field?
(Note that there might not be such a circumstance, as @Dale commented, but there will be for something like a conducting sphere near a charge.)
We derive Gauss's law from Coulomb's law for a single point charge.
We start with the surface integral,
\oint {\bf dA}\cdot{\bf E}=q \oint{\bf d A}\cdot\frac{{\bf r}}{r^3},
of the normal component of ##{\bf E}## over a closed surface surrounding the point charge.
The vector differential of area, ##{\bf dA}##, is an infinitesimal surface element of magnitude dA. Since it is infinitesimal, it approaches a plane surface, tangent to the closed surface. By convention, its vector direction is along the outward normal to the closed surface. The integrand,##\frac{{\bf \hat r}\cdot{\bf dA}}{r^2}##, of the surface integral, can be recognized as the definition of the solid angle, ##d\Omega##, subtended by the differential surface.
Then the surface integral can be written as
$$\oint{\bf dA}\cdot{\bf E}=q\oint d\Omega=4\pi\, q,$$
with the factor ##4\pi## arising as the magnitude of the total solid angle of any closed surface.
If the point charge ##q## were located outside the closed surface, then the surface integral would be zero.
If a plane surface is made to cut the closed integration surface into two parts, then the integrated solid angle over each part of the surface will equal in magnitude the solid angle subtended by the part of the plane surface inside the closed surface. But the two solid angles will be of opposite sign and just cancel. Thus the integral over the closed surface will be ##4\pi q## for a point charge inside the surface, and zero for a point charge outside the surface.
For a collection of point charges, only those inside the surface will contribute to the integral, and we have Gauss's law,
$$\oint {\bf dA}\cdot{\bf E}=4\pi\, Q_{\rm enclosed},$$
where ##Q_{\rm enclosed}## is the net charge within the surface.
  • · Replies 29 ·
  • · Replies 83 ·
