Electric Force and Object Acceleration
An object with a charge of -2.9 microC and a mass of 0.012 kg experiences an upward electric force equal to its weight, leading to an electric field magnitude of 4.1 x 10^4 N/C. When the charge is doubled, the net force equation combines the electric force and gravitational force to determine acceleration. The correct approach involves summing the forces in the vertical direction, resulting in an upward acceleration of 9.81 m/s^2. This acceleration is positive, indicating the net force acts upward. The discussion emphasizes understanding the relationship between electric force, gravitational force, and acceleration.
mli273
1. An object with a charge of -2.9 microC and a mass of .012 kg experiences an upward electric force, due to a uniform electric field, equal in magnitude to its weight.
Part A: Find the magnitude of the electric field. Which I correctly calculated to be 4.1 x 10^4 N/C.
Part B: If the electric charge on the object is doubled while its mass remains the same, find the direction and magnitude of its acceleration.
2. F=ma
3. I'm not really sure how to calculate the acceleration of the problem. Any ideas?
What happens to the electric force if the charge is doubled? What happens to the net force on the object?
ΣF = ma
is the net force doubled as well?
What was the net force originally?
Net force was F=mg so F=(.012)(9.81)= .11772 N
you have two forces, gravity and the electric force due to the electric field.
You need to sum the all of the forces in your system (in the Y direction)
Electric Force = q*E
sum of the forces = 2qE - mg = ma; //solve for a
If the acceleration is greater in than gravity, than the direction is obviously ...
Ok, well a = [2(-2.9x10^-6)(4.1x10^4) - (.012)(9.81)]/.012 = -29.6 m/s^2
But this is not the correct answer according to Mastering Physics.
No, mg is just one of the forces on the object. What's the other? What's the net force?
Hint: To solve part B you won't need the result from part A.
Oh..I get it. So it would be 2q -mg= ma, so the answer would be 9.81 m/s^2 & it's positive because the force is upward. Thank you so much!
