Electric force between charged spheres independent of radius
6 replies · 3K views
tsuwal
This problem may be dull, I know, but maybe there is a hidden math trick that i don't know of. This picture sums up the problem.
So, you should prove by simplifing the integral that [itex]F^e[/itex], the eletric force applied between two spheres, onde with a charge [itex]q_1[/itex] and the other with the charge [itex]q_2[/itex] (distributed evenly in volume, with a charge density [itex]\rho[/itex]) doesn't depend on [itex]R_2[/itex], it only depends on [itex]q_1, q_2[/itex] and [itex]d[/itex]
[itex]F^{e}=\int_V \frac{q_1\rho }{4\pi \delta^{2}} cos(\phi ) dV[/itex]
[itex]F^{e}=\int_V \frac{q_1\rho }{4\pi \delta^{2}} cos(\phi ) dV =\frac{q_1q_2 }{4\pi\frac{4}{3}\pi R_2^{3}}\iint_{0}^{R_2}\frac{cos(\phi )sin(\phi )r^2}{\delta^{2}}drd\phi=\frac{q_1q_2 }{4\pi\frac{4}{3}\pi R_2^{3}}\iint_{0}^{R_2}\frac{cos(\phi )sin(\phi )r^2}{(d-rcos(\phi )^2+(rsin(\phi )^2))} drd\phi=\frac{q_1q_2 }{4\pi\frac{4}{3}\pi R_2^{3}}\iint_{0}^{R_2}\frac{cos(\phi )sin(\phi )r^2}{(d^2+r^2-2drcos(\phi ))} drd\phi[/itex]
How do you simplify this integral or at least show that the expression doesn't depend on [itex]R_2[/itex]? I tried to derivate with respect to [itex]R_2[/itex] but it didn't helped...
If I remember correctly, it is easier to integrate over a spherical shell only. If this is equivalent to a point-charge, the remaining part is easy.
Do you have to use integration? Gauß' law would be so nice...
You are saying that first we could show that a sphere with some charge density is equal to a spherical surface with a surface density choosen to have the same total charge and then simplify the integral. Yeah that could work but still get a pretty dull integral. I just wanted to know if there was some hidden math trick but seems like Gauss's law is the way to go.
No, the idea is to get rid of the r-integration: Show that a spherical shell has the same potential (at some specific point) as a point-charge in the center of the shell. The filled sphere just consists of "many" spherical shells.
mfb said:
Show that a spherical shell has the same potential.
yeah but i was asking for the eletric force not the potencial...
I got the many shperical shells=sphere with some volume density though
If the potential is the same, the electric field and the force are the same as well.
Oh, I think I see the problem: The force is a vector (with variable orientation), you have to add vectors and not their magnitude. That gets messy - calculate the potential instead, this should be easier.
