Electric Force- Finding angle of Force on q1 due to q2 and q3
The discussion focuses on calculating the angle of the resultant force on charge q1 (3.7 mC) due to charges q2 (9.1 mC) and q3 (7.2 mC) using Coulomb's Law. The user initially calculated the distances and angles incorrectly, leading to an erroneous total angle of 210.35 degrees. The correct approach involves determining the forces exerted by q2 and q3 in vector form, calculating their resultant, and then finding the angle relative to the x-axis. The final forces calculated were F12 = 4506.692 N and F13 = 28.99 N.
  • Coulomb's Law for calculating electric forces
  • Vector decomposition for force components
  • Trigonometric functions, specifically arctangent
  • Coordinate geometry for charge positioning
  • Learn how to apply Coulomb's Law to find electric forces between point charges
  • Study vector addition to combine forces in two dimensions
  • Explore trigonometric functions for angle calculations in physics
  • Understand the significance of charge arrangement in electric force calculations
Students studying electrostatics, physics educators, and anyone involved in solving problems related to electric forces and charge interactions.
blackbyron
A charge of q1=3.7mC is located at (x=345, y=(-237))cm. A charge of q2=9.1mC is located at (2.0,5.7)m. A charge of q3=7.2mC is located at ((-27.9),83)m. What is the angle of the force on q1 due to q2 and q3? (deg, relative to +x axis, three significant figures)
Coulomb's Law
Ok so the first step is to find the x,y distance between q1 and q2, and the distance between q1 and q3.
q1 distance to q2 = (-1.45, 8.07)
q1 distance to q3 = (-31.35, 85.37)
so then I find the angle on q1q2 and q1q3.
q1q2 = arctan(8.07/-1.45) = 100.186
q1q3 = arctan(-31.35/85.37) = 110.1645
add the angles together and I got 210.35, and the answer is wrong. Is there anything I'm missing or did something wrong?
Thanks.
Coulomb's Law
You have completely disregarded the sentence marked in red in the problem.
Find the forces of both charges q2 and q3 in vector form, applying Coulomb's Law, calculate the resultant, and find the angle the resultant force encloses with the x axis.
ehild
Coulomb's Law
Thanks.
I think you have lost focus.
The question is " What is the angle of the force on q1 due to q2 and q3?" I have highlighted that part of the question you posted
Forces depend on the size of the charges [you haven't used them] and the direct distance apart - not some (x,y) components of that distance.
ehild
SNAP!
Peter
Thanks, it's not just I'm not focused. I'm just not that clear of the question.
I did find out both forces which are.
F12 = 4506.692N
F13 = 28.99N
But the question is how do I know which one is horizontal or vertical? I did draw the graph, but I'm just confused on how to find which ones face which.
F12 = 4506.692N
F13 = 28.99N
Since the original charges are not arranged in a triangle with a vertical and horizontal side, neither of these forces is horizontal nor vertical.
You now need to find the x- and y- components of each force, so you can combine them.
The x- and y- components you found of the distances will help there.
Thank you so much, I figured out the answer. I forgot about that. :)
10K
10K
10K
