Electric potential at the center of a insulating sphere
The discussion centers on calculating the electric potential at the center of a uniformly charged insulating sphere with a radius of 3.3 m and a total charge of Q = 2.9 × 10-6 C. The Coulomb constant is K = 8.98764 × 109 N·m2/C2. The potential at the center is derived from integrating the contributions of concentric spherical shells, leading to the formula V = (3Q)/(8πεR). The confusion arose from the setup of the limits of integration, which affected the sign of the final answer.
  • Understanding of electric potential and electric fields
  • Familiarity with Coulomb's law and the Coulomb constant
  • Knowledge of integral calculus, particularly in the context of physics
  • Concept of uniformly charged insulating spheres and their properties
  • Study the derivation of electric potential from electric fields in spherical coordinates
  • Learn about the properties of electric fields within and outside uniformly charged spheres
  • Explore the concept of electric potential energy in electrostatics
  • Investigate the application of Gauss's law in calculating electric fields
Students and educators in physics, particularly those focusing on electrostatics, as well as professionals involved in electrical engineering and related fields.
SpringWater
Consider a uniformly charged insulating sphere with radius R and total charge Q in- side the sphere.
If Q = 2.9 × 10−6 C, what is the magnitude of the electric field at r=R/2 K=columbs constant. The answer to this question is E=(K)(Q) / (2)*(R)^(2)
The second part of the question which I am having trouble with is...
If the sphere has a radius of 3.3 m, find the potential at r = 0. The Coulomb constant is 8.98764 × 109 N · m2/C2 . Follow the convention that the electric potential at r = ∞ is zero. answer in units of V
Q=2.9E-6 C
r=3.3m
k=8.98764E9 N*m^2 / C^2
So I have set up the problem as two integrals
that are shown in the picture. I thought that this would give me the electric potential at r=0 however i am still getting it incorrect. I am not sure what I am doing wrong any help would be appreciated.
Thank you,
Have you tried using the fact that the potential inside a spherical shell is constant and is equal to the potential on its surface?
I understood that concept but i guess because this was a two part problem i was trying to incorporate an integral that would relate to the first part of the problem, so no i really didnt...
..in that case the electric potential on the surface would be = (K)*(Q) / (R) Correct?
where R is the radius of the sphere and R=3.3 m
no this is incorrect, so looking back at my integral, i am more sure that my set up was correct, in the orignal post w/ picture. the question now i believe is the sign (-) or (+)?
The second part can be solved by assuming the sphere to be made of thin concentric spherical shell of uniform charge densities. Every shell contributes a potential equal to that on it's surface. The solution is simply obtained by integrating the potentials. Note that Q is evenly distributed throughout the sphere and hence it helps to assign a constant as charge density and then use it.
okay, thank you for the reply i greatly appreciate it.
using the integrals i set up, after simplifying the two i obtain -((3)*(k)*(Q) / (2)*(R)) which is a similar formula i just found a min ago however there formula did not have a negative sign. so why when my method is correct, do i come up with a negative sign assuming that the integral sums up the shells.
I'm a bit confused about how you got your limits of integration. Would you mind explaining? What is the final answer to this problem, by the way?
well i set them up incorrectly that is why i kept coming up with a negative answer. see picture for how i switched them. the worked integral is in the first attached picture however the answer should be positive.
Is the answer 3Q/8πεR? If correct I'll explain my method, else I'll check what I've done wrong and later suggest a solution.
sorry i forgot the picture.
Sunil Simha said:
Is the answer \frac{3Q}{8πεR}. If correct I'll explain my method, else I'll check what I've done wrong and later suggest a solution.
yes, i get the same answer from your (simplified) solution and the same from the two integrals i set up however my problem was i did not set up the limits of integration correctly hence the negative sign.
thank you for your help
  • · Replies 16 ·
  • · Replies 22 ·
