Electric potential at the edge of a thin charged circular plate
The discussion centers on calculating the electric potential at the edge of a thin charged circular plate using calculus. The user derived the charge element dq and the potential dV, leading to the expression V = (-σR/πε). The confusion arose from integrating the limits from 0 to π/2, resulting in a negative sign for the potential. The correct approach involves integrating from π/2 to 0, which aligns with the positive nature of the radius dr during integration.
  • Understanding of electric potential and charge distribution
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of circular geometry and trigonometric functions
  • Basic principles of electrostatics, including the concept of surface charge density (σ)
  • Study the derivation of electric potential for different geometries, such as spherical and cylindrical shapes
  • Learn about the implications of charge distribution on electric fields and potentials
  • Explore advanced integration techniques in calculus, focusing on variable limits
  • Investigate the relationship between surface charge density and electric potential in electrostatics
Students and professionals in physics, electrical engineering, and applied mathematics who are studying electrostatics and electric potential calculations.
Aryamaan Thakur
To find the electric potential at the edge of a thin circular plate of radius R carrying uniformly distributed charge of surface density σ
dV = (1/4πε) dq/r
l = rθ
My question might sound stupid to you but please clear my confusions.
I'm taking an circular arc like element on the plate. That arc has a radius of 'r' (AB) and the radius is inclined at an angle 'θ' with OA (∠OAB).
The area between arc of radius r and r+dr is dA.
dA = 2θr.dr
The charge on this area will be dq
dq = σ dA = 2σθr.dr
From ΔAOB, the relation between r and R is:
r = 2Rcosθ
taking derivative on both sides gives:
dr = -2Rsinθ
Potential due to this area at edge A is dV
dV = (1/4πεr) dq = (1/4πε) (-4σRθsinθ.dθ)
So, V comes out to be ∫ dV = (-σR/πε) ∫ θsinθ.dθ
taking limits from 0 to π/2, the integral gives 1
V = (-σR/πε)
I got the right magnitude but wrong sign. Some resources on internet say I should integrate from π/2 to 0.
What is the problem in integrating from 0 to π/2? Why am I getting a negative sign? And why should I integrate from π/2 to 0?
Because you started with dr, which is only going to be positive if your integration range is from 0 to 2R (not the other way around).
r=0 corresponds to θ=π/2.
It was just this...😂 I solved the whole problem and put the wrong limits😂😂😂
Thanks a lot:smile: You cleared my confusion.
  • · Replies 16 ·
