Electric potential difference between two points in a constant field at an angle
5 replies · 2K views
tag16
Two points (A and B) are shown in a constant electric field of E = 850 N/C. The distance between A and B is L = 2 m. The line joining the two points makes an angle of 40 degrees with the electric field. Determine the electric potential difference (in Volts) between points A and B -- that is VA - VB.
E_s cos(theta)=-Ed
would I just do E(cos theta) or -Ed? or are neither right?
The way I like to think of it is that the change in potential V is the work that must be done per unit charge to move a charge from A to B. The work is the force that must be exerted times the distance for which it is exerted. So we have
V = W/q and W = Fd or V = Fd/q
The electric field causes a force on the charge we are moving, F = qE.
However this force is not in the exact direction we are pushing the charge. So the force we need to overcome is actually qE*cos(A) where A is the angle between the E field and the direction we are going. That leaves us with a potential difference of
V = Fd/q = qE*cos(A)*d/q.
yeah I thought that might be it so I tried it that way but still got the wrong answer
I'm not supposed to show you the calculation for fear of spoiling the experience for you. But if you show your calc, we can check it.
