Electric Potential of a Charged Disk
The discussion focuses on calculating the electric potential at any point on the positive x-axis of a charged disk using integration techniques. The participants derived a formula for the electric potential, Vx, and explored the reference point for potential, questioning whether it should be at infinity. They concluded that as x approaches infinity, the potential approaches that of a point charge, confirming that the assumption of zero potential at infinity is valid. The conversation highlights the importance of correctly applying limits in physics calculations.
  • Understanding of electric potential and its mathematical representation
  • Familiarity with integration techniques in electromagnetism
  • Knowledge of limits and asymptotic behavior in calculus
  • Basic concepts of point charges and their electric fields
  • Study the derivation of electric potential for different charge distributions
  • Learn about the concept of electric field lines and their relation to potential
  • Explore advanced integration techniques in electromagnetism
  • Investigate the implications of reference points in electric potential calculations
Students in introductory electromagnetism courses, physics educators, and anyone interested in the mathematical foundations of electric potential and charge distributions.
thegreenlaser
I was working on E&M I homework with my friend, and the final question was to find the electric potential at any point on the positive x-axis of a charged disk (where the x-axis is perpendicular to the centre of the disk) We solved this easily enough, starting with a point charge and integrating the electric potential in steps. We got to the end and had a formula for the electric potential at point x (it was the correct answer). Thing is, we know that potential is always in reference to some 'zero' point (infinity in the case of a point charge), so we decided to figure out if that point was infinity for a disk as well, and if not, what it would be. I worked on that for a while and came out with something... but neither of us is really sure about how to interpret it. I'm still in first year so I'm very inexperienced with coming up with this sort of thing on my own and I apologize for any "bad" methods I used. I fully expect to have messed something up, so please tell me what I've done wrong. If I managed to do everything right, my questions are at the end of the pdf that I've attached (I was having trouble with latex, so I just scanned some notes that I made about this)
Help is greatly appreciated. Sorry if anything is unclear.
I always get a bit uneasy when dealing with infinities. But I see 2 things in your analysis:
1. The very first thing you assume in your analysis (in taking the electric potential due to a point charge) is that the potential at infinity is zero.
2. As x -> infinity, x >> r and so Sqrt[x^2+r^2] is approximately Sqrt[x^2] or just x. So in your equation Vx=q/(2*Pi*r^2)*(Sqrt[x^2+r^2] -x), the (Sqrt[x^2+r^2] -x) could be said to approach zero. Maybe that's not technically mathematically correct, but physically that's what has to happen.
One thing to note is that as x becomes >> r, the disk approximates a point charge with respect to the distance x. The limit with a finite r and as x -> ∞ should be the same as a point charge.
Ah... so I just failed at limits. I guess I was looking for some sort of "constant divided by infinity" term rather than actually taking the limit properly. If having the reference point at infinity works, then I guess the rest of what I did is kind of pointless. I found that other x_0 but it's kind of a useless one because it's dependent on x. Well, thanks for showing me my error. I can't believe that neither my friend or me saw that.
  • · Replies 21 ·
