Electrical properties of standard lubrication oil (SAE)
The discussion revolves around the electrical properties of standard lubrication oils, specifically engine oils such as SAE grades. Participants seek to understand conductivity, dielectric constants, and the impact of additives on these properties, as well as the implications for sensor design in monitoring oil conditions.
  • Experimental/applied
  • Some participants mention that conductivity values for different oils can vary significantly, from less than 10 to over 2000 pico siemens per meter, depending on the oil and its additives.
  • There is a suggestion that the dielectric constant of oils can range from 2.1 to 2.4 for base oils, while additives may increase this value to between 6 and 10.
  • One participant expresses skepticism about finding reliable conductivity specifications, noting that manufacturers may not disclose such data due to the need for ongoing monitoring.
  • Several participants discuss the challenges of measuring electrical properties in used oil, which may contain contaminants that affect conductivity.
  • Concerns are raised about the feasibility of using MEMS sensors in engine oil due to the harsh conditions and variability of oil quality over time.
  • Some participants propose that used engine oil is likely to be more conductive than new oil due to the presence of carbon, metal particles, and oxidation products.
  • There are references to specific ASTM standards for testing the electrical properties of insulating liquids, suggesting a structured approach to understanding these properties.
  • One participant suggests that integrating sensors into oil filters could provide cleaner samples for measurement.
  • Another participant mentions that optical sensors could be a viable alternative for assessing oil quality based on clarity.
Participants express a range of views on the availability and reliability of data regarding the electrical properties of lubrication oils. There is no consensus on specific conductivity values or the best methods for measuring these properties, and the discussion remains unresolved regarding the practical implications for sensor design.
Limitations include the variability of oil properties based on usage, the influence of contaminants in used oil, and the lack of standardized specifications from manufacturers. The discussion also highlights the complexity of measuring electrical properties in real-world conditions.
This discussion may be of interest to researchers and engineers involved in lubrication technology, oil condition monitoring, and sensor development, particularly in automotive and industrial applications.
Saravanakumar
What are the electrical properties of standard lubrication oil (Engine oil)? Where to find? Please give the sources. I have tried my best on the internet.
My guess is you will not find them, if a manufacturer adds a "spec" for conductivity then they have to monitor and maintain it. There may be some "rule of thumb" values out there, but once in an engine, break down and degradation, carbon, sludge, metal flakes - all bets are off.
So this begs the question - why do you ask?
Which electrical properties, and specifically, what manner of oil? "Engine oil" itself is overly broad (mineral oil? if synthetic, what type?).
One way to approach this is to answer, "How are the electrical properties of oil tested?" A sampling ...
ASTM D257 - 14
Standard Test Methods for DC Resistance or Conductance of Insulating Materials
ASTM D3487 - 16
Standard Specification for Mineral Insulating Oil Used in Electrical Apparatus
ASTM D1169 - 11
Standard Test Method for Specific Resistance (Resistivity) of Electrical Insulating Liquids
Another is to research existing oil applications in electrical apparatus. This write-up on oil conductivity in HVDC gear may help define your thoughts.
https://opus4.kobv.de/opus4-fhws/fi...ion_Assessment_of_HVDC_Insulation_Systems.pdf
CWatters said:
Thank you for your reply. I have already checked that website. Since I am research scholar, I need data from trust ful source.
I am developing MEMS oil condition monitoring sensor. As a first step, I decided to make viscosity sensor. The model I have made works only in the non-conductive fluids. If lubrication oil has significant conductivity, then the design has to be changed. So I am collecting all the information about lubrication oil.
I need electrical and mechanical properties of below lubrication oil:
Engine oil SAE 15W-40, SAE 10W-40, SAE 10W-60, SAE 5W-40, SAE 0W-30, SAE 30
How much conductivity is too much?
Have you tried contacting engine oil manufacturer engineering departments?
I can't recall seeing conductivity listed in any lubrication oil product data sheets, but they almost always provide the basics (viscosity, density, flash point, pour point, volatility, etc.).
Mineral oils and most of the synthetic oils are good insulators .
Their electrical properties are usually characterised by breakdown voltage and dielectric constant .
OK - so high conductivity will cause the test you have now to have problems. Then you are concerned about worst case? I still doubt there would be any good data - since you need to consider USED oil. In the field there are too many variables, including when the owner changes the oil to a different brand or spec. Since this is mostly an academic pursuit, another approach would be to limit the study to a few brands / types - etc. Go to a local shop and get some samples of used oil that they know the brand of - for example a known, reliable customer.
I would echo to reach out to the Manufacturers and ask about the worst case - I am sure they have some data, but like I said it is not part of their specification.
Lastly - Engine oil is probably the last place I would expect a MEMS sensor to be effective in the real world. Engine oil "goes bad" in so many ways - moisture & coolant, sludge, metallic flakes, thermal breakdown, even fuel, or customer added additives. Look at the http://www.blackstone-labs.com/standard-analysis.php, I can not see the sensor surviving these variables, not to mention engine oil can routinely hit 125C most Silicon chips often max around 150C - and 125 is something of a design limit. . Sorry to be so negative.
One approach would be to integrate the sensor into the oil filter, after the filter, so the sensor is changed with every oil change, and "sees' the cleanest oil having just been filtered.
Windadct said:
Lastly - Engine oil is probably the last place I would expect a MEMS sensor to be effective in the real world. Engine oil "goes bad" in so many ways - moisture & coolant, sludge, metallic flakes, thermal breakdown, even fuel, or customer added additives. Look at the http://www.blackstone-labs.com/standard-analysis.php, I can not see the sensor surviving these variables, not to mention engine oil can routinely hit 125C most Silicon chips often max around 150C - and 125 is something of a design limit. . Sorry to be so negative...
Add surviving a cold weather start-up to your list. I don't have in-depth experience with motor oil (unless you count doing my own oil changes), but in industrial gearbox applications, room temperature viscosity is significantly higher than when oil is at normal operating temperature. It is doubtful a MEMS turbine type viscometer would remain intact during the initial pressure surge (although this could be designed around by adding an isolation valve that opens up only after oil temperature has risen).
Aside: While poking around the web, I learned late model BMW engines feature an oil condition sensor that measures temperature, level, and oil quality. Didn't find a detailed explanation of exactly how, but dielectric strength is measured as a proxy for oil quality. PDF file with sensor info. http://www.m3post.com/forums/attachment.php? s=ebb899a0ff1cdca95dd4c0ef202f8c0f&attachmentid=266653&d=1241794389
My money is on an optical sensor looking at clarity.
Used engine oil will be more conductive than new oil because it will contain particles of carbon and metal plus oil oxidation products. Conductivity will increase with age.
Manolis said:
Used engine oil will be more conductive than new oil because it will contain particles of carbon and metal plus oil oxidation products. Conductivity will increase with age.[/Q
Their electrical properties are usually characterised by breakdown voltage and dielectric constant.
Yes, I agree with you. If we have oil(non-conductive or dielectric) between two parallel plates, oil will become a conductor above the breakdown voltage. Then now all I need to know is what is the dielectric constant range of the engine oil.
My simple question is that why no one characterises the engine oil so far?
Is experimenting the only way to know the electrical property of engine oil?
  • · Replies 117 ·
11K
  • · Replies 74 ·
9K
11K
