Calculating Total Charge on Non-Uniformly Charged Sphere
The discussion focuses on calculating the total charge on a non-uniformly charged sphere with a surface charge density defined as ##ρ_s(φ)=ρ_{so}(cosφ)^2##. The total charge is derived using the surface element ##dA=a^2sinφdφdθ##, leading to the expression ##Q=∫ρ_{so}(cosφ)^2a^2sinφdφdθ## over the specified limits. The integration involves a double integral with φ ranging from 0 to π and θ from 0 to 2π, ultimately yielding the total charge as ##Q=\frac{4π}{3}ρ_{s0}a^2##.
  • Understanding of surface charge density and its mathematical representation.
  • Familiarity with spherical coordinates and integration techniques.
  • Knowledge of polar coordinates and their application in double integrals.
  • Basic principles of electrostatics, particularly related to charge distributions.
  • Study the derivation of surface charge density in electrostatics.
  • Learn about double integrals in spherical coordinates.
  • Explore applications of surface integrals in physics problems.
  • Investigate the implications of non-uniform charge distributions on electric fields.
Students in physics, particularly those studying electromagnetism, as well as educators and anyone interested in advanced calculus applications in physical scenarios.
doktorwho
A sphere of radius ##a## is non-uniformly charged on its surface with a charge whose surface density is ##ρ_s(φ)=ρ_{so}(cosφ)^2## where ##φ## is the angle measures from the z axis, (0≤φ≤π) and ##ρ_{s0}## is a constant. Determine the expression for the total charge distributed on the sphere.
##dQ=ρ_sdS##
I know I am supposed to find the small surface element on which to integrate but the surface charge density is given by the angle and how am i supposed to make the surface element be in angle form. I tried thinking like this: In a circle the element ##dL## that is the small part of the circumference is ##rdφ## but don't know how to use that on the sphere..
The solution should be ##Q=\frac{4π}{3}ρ_{s0}a^2##
The problem i have now is how to start. I have to find the surface element and i don't know how, can you help?
Welcome to PF!
Look at the last page of this link: http://web.mit.edu/8.02t/www/materials/modules/ReviewB.pdf
But note that here they use the symbol ##\theta## for your ##\varphi##.
TSny said:
Welcome to PF!
Hi, its great to be here :D
I have solved the problem, i figured that the part of the sphere that is under the fixed angle can be integrated,
##dA=2rπdl## where the circumference at some radius ##r## that is equal to ##r=asinφ## multiplied by the ##dl## element equaling to ##adφ## gives out the area and the integral becomes ##Q=∫2πa^2ρ_{so}(cosφ)^2sinφ## integrated on the interval ##[0,π]## but just out of curiosity how would i use the area you provided?
The surface element is ##dA=a^2sinφdφdθ## and the integral becomes ##Q=∫ρ_{so}(cosφ)^2a^2sinφdφdθ##? There are two differentials now, how to use this?
The integral with respect to θ is easy, so do that first.
Well the limits are ##[0, π]## so it should be ##π## right? But then I am mising a factor of ##2## so it should be ##2π## somehow..
doktorwho said:
the limits are [0,π]
In polar, to cover the sphere, one angle goes 0 to π and the other from 0 to 2π.
So i integrate one angle from ##[0, π]## and the other ##[0, 2π]##? How would i put the limits for the general expression?
You are asking about the notation? ##\int^{\pi}_{\phi=0}\int^{2\pi}_{\theta=0}##.
oh yeah it would be a double integral, thanks :D!
10K
  • · Replies 18 ·
